Community Member
vpdn-group configuration
I am replacing a 2611 with a 2811, I am copying the setups from the old router, I have a question about the following.. on the old router there was no line in my config for l2tp - I do not seem to be able to find any configuration options for it - I don't nec want to get rid of it but want to mainly know how to config it and if the same options apply for pptp? I think I have gone into all of the listed options and put in "?" is l2tp missing from the help?
vpdn-group 1
! Default PPTP VPDN group
accept-dialin
protocol pptp
l2tp tunnel password 7
Silver
Re: vpdn-group configuration
Which IOS version are you using? , if you are using lower version, need to upgrade to version 12.4(6)
Sample VPN group configuration:
vpdn-group 2
! Default L2TP VPDN group
description L2TP for Dial
accept-dialin
protocol l2tp
virtual-template 2
l2tp tunnel password xxxxx
Community Member
I am running 12.4(11). The commands for l2tp tunnel do not appear to be working, this is the kind of resp I get when attempting to use anything formatted with l2tp....
(config-vpdn)#l2tp tunnel password test
% Invalid input detected at '^' marker.
318
