VPN 1710 and VPN Client - "maybe" routing problem
I was able to get 1710 working with 3DES and CISCO VPN Client 3.6.1. with local aaa authorization.
When I am connected to the VPN I can ping the IP address of the VPN router
(24.x.x.x.) and I can ping the internal interface (192.168.x.x) of the router.
The problem is that I can't ping nothing else - for example: the hosts in the corporate net (192.168.x.x.)
Configuration:
Internal IP of the router: 192.168.x.x
External IP of the router: 24.x.x.x
ippool for Clients: 10.10.10.x
The IP address of the Client after connection is correct: 10.0.0.x (from the pool)
May be I am missing something into 1710 confg? Do I need to NAT the internal interface? The default gateway of the net is FreeBSD system, not the 1710 router.
Any ideas are welcome.
Miro Pendev
IT Administrstor
1 ACCEPTED SOLUTION
Re: VPN 1710 and VPN Client - "maybe" routing problem
You'll quite often lose the first ping because an ARP has to be sent and replied to, but if you're getting subsequent pings then that's OK.
As for being able to browse the Internet while the tunnel is up, you need to enable split tunnelling. Add the following:
> access-list 110 permit ip 192.168.1.0 0.0.0.255 192.168.1.0 0.0.0.255
> crypto isakmp client configuration group my_usergroup
> acl 110
This means the client will only encrypt traffic to the 192.168.1.0 network, all other traffic will go out in the clear to the Internet.
Here's your problem:
unquote;
When you ping an internal device, the source address of the packet is going to be 10.10.10.x from your VPN pool. Your internal devices are going to send their responses to their default gateway, which is not the 1710.
Either put a static route on the FreeBSD system for the 10.10.10.x network pointing to the inside address of the 1710, or make your pool of addresses part of the 192.168.x.x subnet, then the router will proxy-ARP for those addresses and everything will work fine.
Thanks for your reply!
I would prefer to use the proxy-ARP way - 192.168.x.x. subnet for the remote clients. So I did! I changed the client pool and they are with 192.168.x.x ip addresses.
In this situation from the remote Cisco VPN client I can not ping neither external IP (24.x.x.x) nor internal IP (192.168.x.x) of the router.
Do I need to enable the proxy-arp?
The configuration of the 1710 is "by the PDF"... i do not have any extra options.
I can post the config so you can take a look - just let me know.
Miro
Yes, can you post the config of the router please, make sure you xxx out your external IP address.
In particular, did you put the pool of addresses into the same subnet of 192.168.x.x, or a different one? If it's different, then the internal hosts are still going to send the replies to the FreeBSD box.
Yes, they are in the same subnet.
By the way - I noticed that I can ping the internal hosts from 192.168.1.x net - but not the interfaces of the router. The fist ping didn't work, but the second was fine. Because if WINS I can connect to internal servers by \\servername, but I can't browse the network.
The second thing is that the client doesn't have Internet access after Cisco VPN client is connected. Is it possible to keep the internet access on the client side and still use the VPN channel?
Miro
Here is the config for 1710:
version 12.2
service timestamps debug uptime
service timestamps log uptime
hostname VPN-Router
aaa new-model
aaa authentication login userauthen local
aaa authorization network groupauthor local
aaa session-id common
enable secret 5 ******************
enable password ***************
username user password 0 ***************
username user2 password 0 ***************
memory-size iomem 25
ip subnet-zero
ip name-server 201.x.x.x
ip audit notify log
ip audit po max-events 100
ip ssh time-out 120
ip ssh authentication-retries 3
crypto isakmp policy 3
encr 3des
authentication pre-share
group 2
key ***********
wins 192.168.1.x
pool ippool
crypto ipsec transform-set myset esp-3des esp-md5-hmac
crypto dynamic-map dynmap 10
set transform-set myset
crypto map clientmap client authentication list userauthen
crypto map clientmap isakmp authorization list groupauthor
crypto map clientmap client configuration address respond
crypto map clientmap 10 ipsec-isakmp dynamic dynmap
interface Ethernet0
description connected to Internet
ip address 24.x.x.x 255.255.255.x
full-duplex
interface FastEthernet0
description connected to EthernetLAN
ip address 192.168.1.x 255.255.255.0
speed auto
full-duplex
ip local pool ippool 192.168.1.40 192.168.1.50
ip default-gateway 24.x.x.1
ip classless
ip route 0.0.0.0 0.0.0.0 24.x.x.1
no ip http server
ip pim bidir-enable
banner motd
Baner
line con 0
exec-timeout 0 0
line aux 0
line vty 0 4
password ****************
transport preferred none
line vty 5 10
end
> acl 110
Worked as a charm :-)
Thanks a lot!
Miro
104
