VPN 3.6.3 and Pix 515 6.2connection problems.
We have upgraded our pix image to 6.2 but unfortunately can not get client 3.6.3 to connect. The message we get is "Failed to establish a secure connection to the security gateway." We don't have a problem connecting with a client 3.2 or 3.5 however. Did anyone have a similar problem?
1 ACCEPTED SOLUTION
Re: VPN 3.6.3 and Pix 515 6.2connection problems.
VPN Client 3.6 still supports DES/MD5; however, support for DES/SHA is no longer available.
http://www.cisco.com/univercd/cc/td/doc/product/vpn/client/3_6/361_clnt.htm#xtocid18
If the proposal is not configured for DES/SHA and you are still having issues connecting, then post the isakmp and ipsec debug from the pix and the logs from the client and we can take a look at it to see what is going on.
Arul
Arul
thanks a lot Arul,
I've added a couple of lines below and was able to connect fine.
isakmp policy 10 hash md5
crypto ipsec transform-set strong esp-des esp-md5-hmac
regards,
Mark
99
