vpn 3.x client and IPSec tunnel access on same interface
Is it possible to access other IPSec tunnels (say between offices) on the external interface when using the VPN client to connect to the same interface on a PIX 6.1? If not can you suggest a solution that doesn't involve the client having to make more than one connection.
Shaun
1 REPLY
Re: vpn 3.x client and IPSec tunnel access on same interface
I have a similar problem:
It seems I can have a pix6.0 accepting clients with the vpn 3.0 client OR a connection with another pix 6.0, BUT not both at the same time.
98
