VPN 3000 : lan to lan (to dynamic IP address)
We are trying to configure a LAN-LAN VPN between a VPN3000 and a 3G (Sarian) router. The 3G router receives a dynamic IP address but the VPN3000 requires a Peer address when configuring a LAN-LAN connection.
How can I configure this sort of connection when the remote client has a dynamic address - the VPN3000 will not accept the config without a peer address.
many thanks,
Andy.
1 REPLY
Re: VPN 3000 : lan to lan (to dynamic IP address)
Hi Andy,
You can configure the concentrator to accept L2L connection from a dynamic peer. Following is the config example :
http://www.cisco.com/en/US/products/hw/vpndevc/ps2284/products_configuration_example09186a00801dd672.shtml
HTH,
Please rate if it helps,
Kamal
298
