VPN 3000 Starts Authentication and then Quits
Out of nowhere, my VPN 3000 has started deleting connections for a couple of accounts as soon as they authenticate. I type in the user name and password; it authenticates, negotiates security policies, and then says "Not Connected". I turned on full logging on the client and this is the output. Can anyone help? Since I’m only allowed to post a certain amount of characters, I’ll break into a few posts. Thanks!
Cisco Systems VPN Client Version 4.0.2 (D)
Copyright (C) 1998-2003 Cisco Systems, Inc. All Rights Reserved.
Client Type(s): Windows, WinNT
Running on: 5.1.2600
177 19:52:05.141 03/24/04 Sev=Info/4 CM/0x63100002
Begin connection process
178 19:52:05.141 03/24/04 Sev=Info/4 CM/0x63100004
Establish secure connection using Ethernet
179 19:52:05.141 03/24/04 Sev=Info/4 CM/0x63100024
Attempt connection with server "1.1.1.1"
180 19:52:05.141 03/24/04 Sev=Info/6 IKE/0x6300003B
Attempting to establish a connection with 1.1.1.1.
181 19:52:05.151 03/24/04 Sev=Info/4 IKE/0x63000013
SENDING >>> ISAKMP OAK AG (SA, KE, NON, ID, VID(Xauth), VID(dpd), VID(Nat-T), VID(Frag), VID(Unity)) to 1.1.1.1
182 19:52:05.572 03/24/04 Sev=Info/5 IKE/0x6300002F
Received ISAKMP packet: peer = 1.1.1.1
183 19:52:05.572 03/24/04 Sev=Info/4 IKE/0x63000014
RECEIVING <<< ISAKMP OAK AG (SA, KE, NON, ID, HASH, VID(Unity), VID(Xauth), VID(dpd), VID(Frag), VID(?), VID(?)) from 1.1.1.1
184 19:52:05.572 03/24/04 Sev=Info/5 IKE/0x63000001
Peer is a Cisco-Unity compliant peer
185 19:52:05.572 03/24/04 Sev=Info/5 IKE/0x63000001
Peer supports XAUTH
186 19:52:05.572 03/24/04 Sev=Info/5 IKE/0x63000001
Peer supports DPD
187 19:52:05.572 03/24/04 Sev=Info/5 IKE/0x63000001
Peer supports IKE fragmentation payloads
188 19:52:05.572 03/24/04 Sev=Info/5 IKE/0x63000001
Peer supports DWR Code and DWR Text
189 19:52:05.582 03/24/04 Sev=Info/6 IKE/0x63000001
IOS Vendor ID Contruction successful
Re: VPN 3000 Starts Authentication and then Quits
Part 2
190 19:52:05.582 03/24/04 Sev=Info/4 IKE/0x63000013
SENDING >>> ISAKMP OAK AG *(HASH, NOTIFY:STATUS_INITIAL_CONTACT, VID(?), VID(Unity)) to 1.1.1.1
191 19:52:05.582 03/24/04 Sev=Info/4 IKE/0x63000082
IKE Port in use - Local Port = 0x01F4, Remote Port = 0x01F4
192 19:52:05.582 03/24/04 Sev=Info/4 CM/0x6310000E
Established Phase 1 SA. 1 Crypto Active IKE SA, 0 User Authenticated IKE SA in the system
193 19:52:05.632 03/24/04 Sev=Info/5 IKE/0x6300002F
194 19:52:05.632 03/24/04 Sev=Info/4 IKE/0x63000014
RECEIVING <<< ISAKMP OAK TRANS *(HASH, ATTR) from 1.1.1.1
195 19:52:05.632 03/24/04 Sev=Info/4 CM/0x63100015
Launch xAuth application
196 19:52:05.972 03/24/04 Sev=Info/4 IPSEC/0x63700008
IPSec driver successfully started
197 19:52:05.972 03/24/04 Sev=Info/4 IPSEC/0x63700014
Deleted all keys
198 19:52:09.898 03/24/04 Sev=Info/4 CM/0x63100017
xAuth application returned
199 19:52:09.898 03/24/04 Sev=Info/4 IKE/0x63000013
SENDING >>> ISAKMP OAK TRANS *(HASH, ATTR) to 1.1.1.1
200 19:52:10.239 03/24/04 Sev=Info/5 IKE/0x6300002F
201 19:52:10.239 03/24/04 Sev=Info/4 IKE/0x63000014
202 19:52:10.239 03/24/04 Sev=Info/4 IKE/0x63000013
203 19:52:10.239 03/24/04 Sev=Info/4 CM/0x6310000E
Established Phase 1 SA. 1 Crypto Active IKE SA, 1 User Authenticated IKE SA in the system
204 19:52:10.249 03/24/04 Sev=Info/5 IKE/0x6300005D
Client sending a firewall request to concentrator
205 19:52:10.249 03/24/04 Sev=Info/5 IKE/0x6300005C
Firewall Policy: Product=Cisco Systems Integrated Client, Capability= (Centralized Protection Policy).
206 19:52:10.249 03/24/04 Sev=Info/4 IKE/0x63000013
207 19:52:11.270 03/24/04 Sev=Info/5 IKE/0x6300002F
208 19:52:11.270 03/24/04 Sev=Info/4 IKE/0x63000014
RECEIVING <<< ISAKMP OAK INFO *(HASH, DWR) from 1.1.1.1
209 19:52:11.270 03/24/04 Sev=Info/4 IKE/0x63000080
Delete Reason Code: 4 --> PEER_DELETE-IKE_DELETE_NO_ERROR.
210 19:52:11.270 03/24/04 Sev=Info/5 IKE/0x6300003C
Received a DELETE payload for IKE SA with Cookies: I_Cookie=443A8D23CAFCACA8 R_Cookie=95FD2F7271E6DCBB
211 19:52:11.270 03/24/04 Sev=Info/4 IKE/0x63000017
Marking IKE SA for deletion (I_Cookie=443A8D23CAFCACA8 R_Cookie=95FD2F7271E6DCBB) reason = PEER_DELETE-IKE_DELETE_NO_ERROR
212 19:52:11.981 03/24/04 Sev=Info/4 IKE/0x6300004A
Discarding IKE SA negotiation (I_Cookie=443A8D23CAFCACA8 R_Cookie=95FD2F7271E6DCBB) reason = PEER_DELETE-IKE_DELETE_NO_ERROR
213 19:52:11.981 03/24/04 Sev=Info/4 CM/0x6310000F
Phase 1 SA deleted before Mode Config is completed cause by "PEER_DELETE-IKE_DELETE_NO_ERROR". 0 Crypto Active IKE SA, 0 User Authenticated IKE SA in the system
214 19:52:11.981 03/24/04 Sev=Info/5 CM/0x63100025
Initializing CVPNDrv
215 19:52:11.981 03/24/04 Sev=Info/4 IKE/0x63000001
IKE received signal to terminate VPN connection
216 19:52:11.981 03/24/04 Sev=Info/4 IPSEC/0x63700014
Deleted all keys
217 19:52:11.981 03/24/04 Sev=Info/4 IPSEC/0x63700014
Deleted all keys
218 19:52:11.981 03/24/04 Sev=Info/4 IPSEC/0x63700014
Deleted all keys
219 19:52:11.981 03/24/04 Sev=Info/4 IPSEC/0x6370000A
IPSec driver successfully stopped
Do you have a NAT device in front of the client. You may check if the NAT setting cause this problem. The other things is the personal firewall on the client side terminate the tunnel.
I have to say this looks like the client(s) are coming from behind a NAT/NAPT device.
I saw the very same thing with multiple VPN clients behind a PIX 501 trying to connect to a single VPN concentrator.
If this is the case, you could use the NAT-T or IPSEC over UDP features available to you with the VPN 3000 and VPN client
Relevant NAT-T article:
http://www.cisco.com/en/US/customer/products/sw/secursw/ps2276/products_configuration_example09186a008010edf4.shtml
Hope this helps.
I am behind a pix 501... but have been for a year now and have never had a problem. All of the sudden one evening it stopped working. I will look at NAT-T. Thanks.
I looked at the logs on the concentrator and this is what is happening at the same time the client is erroring out.
211 03/24/2004 20:10:34.690 SEV=5 IKE/132 RPT=17 68.89.130.37
Group [VPN-Admin] User [mickeymouse]
Cannot obtain an IP address for remote peer
213 03/24/2004 20:10:34.700 SEV=5 IKE/194 RPT=18 68.89.130.37
Sending IKE Delete With Reason message: No Reason Provided.
If you can make changes to the concentrator and client, I can see no harm in configuring NAT-T (this feature was not available when I had this problem so I used IPSEC over UDP).
For information are you trying to run more that one tunnel through the PIX? as this could cause problems for IKE phase 1 as well as ESP.
Cheers.
I tried NAT-T and it didn't work. Nothing has changed, but it just stopped working. The vpn concentrator is saying all the ip's in my pool are in conflict, yet there is nothing else on the switch and this is in the dmz...
The address I assign myself doesn't come from the pool, rather i define it in the user name, so I have the same one every time.
This document describes one of the error messages seen in your concentrator logs.
http://www.cisco.com/en/US/products/hw/vpndevc/ps2284/products_tech_note09186a0080094eca.shtml
It seems to be suggesting that your pool may not be configured correctly, or no address assignment mode is currently configured.
I would also be looking as to why you are getting any type of IP address conlficts occuring. I assume you have checked that no devices respond to the addresses defined in your pool(s).
627
