vpn 3005 concentrator help
I just bought a cisco 3005 vpn concentrator, i managed to configure the ssl vpn and ipsec vpn everything worked fine, after that I decided to upgrade the software release to the “4.1.7.J 21-DEC-2005”, i logged on back again and the link “Configuration > Tunneling and Security > WebVPN > Cisco SSL VPN Client” in not there anymore.
Does anyone know what happened and how to get it back again?
Thanks very much in avdvance.
1 REPLY
Silver
Re: vpn 3005 concentrator help
Upgrading to a new version of the VPN 3000 Concentrator software does not automatically overwrite the existing configuration file. Configuration options for new features are not automatically saved to the configuration file on an upgrade. The HTML Manager displays "Save Needed" (rather than "Save") to indicate that the configuration needs to be saved. If the configuration is not saved, then on the next reboot, the new configuration options are added again. If you need to send the configuration file to the TAC, save the running configuration to the configuration file first.
http://www.cisco.com/en/US/products/hw/vpndevc/ps2284/prod_release_note09186a008049e06a.html#wp560292
http://www.cisco.com/en/US/products/hw/vpndevc/ps2284/products_qanda_item09186a0080094cf4.shtml
93
