VPN 3005 Concentrator Radius problems
I have a problem with getting Radius Authentication to work with new created groups.
We already have 32 groups working [we're matching groupname against OU= in the Certificate]
When I add group 33 this group will not autenticate against the Radius Server.
Have found a similar problem in bugid CSCdz82620
http://www.cisco.com/cgi-bin/Support/Bugtool/onebug.pl?bugid=CSCdz82620
Have also upgrade software to latest on Concentrator Version 4.0.1.C.
Do anyone have any idea how to solve this or confirm that this is a Bug ?
/Best Regards Stefan Kristiansson
29554 08/15/2003 08:46:26.770 SEV=4 AUTH/15 RPT=20890
Server name = 10.240.2.20, type = RADIUS,
group = TESTGROUP, status = Not-in-service
29556 08/15/2003 08:46:26.770 SEV=4 AUTH/9 RPT=11
Authentication failed: Reason = No response from server
handle = 802, server = 10.240.2.20, user = testuser
29558 08/15/2003 08:46:26.770 SEV=7 AUTH/13 RPT=803
Authentication session closed: handle = 802
  • Other Security Subjects
Re: VPN 3005 Concentrator Radius problems
Not sure, but check out if there is any limitation on no. of groups that can be addes, this does not look to be a bug.
I also thought there could be a limitation, but I've checked all whitepapers and I can't find such a limitation described anyware.
/Brgrds Stefan Kristiansson
3243
