VPN 3015 consentrator to Clinet connection lost
Dear All,
I have a problem on a VPN network, I have a VPN 3015 and users using the VPN client. ( both is version 3.6).
The problem is that some 10-20 users losing there conection after a while and need to reconect. The log information on the client is:
123 20:05:22.633 10/17/02 Sev=Info/4 IKE/0x63000013
SENDING >>> ISAKMP OAK INFO *(HASH, NOTIFY:DPD_REQUEST) to 212.242.88.234
124 20:05:27.633 10/17/02 Sev=Info/6 IKE/0x6300003D
Sending DPD request to 212.242.88.234, seq# = 4003831256
125 20:05:27.633 10/17/02 Sev=Info/4 IKE/0x63000013
126 20:05:33.132 10/17/02 Sev=Info/5 IKE/0x63000018
Deleting IPsec SA: (OUTBOUND SPI = 14E329B8 INBOUND SPI = EEE683F8)
127 20:05:33.132 10/17/02 Sev=Info/5 IKE/0x63000018
Deleting IPsec SA: (OUTBOUND SPI = 4DD021E8 INBOUND SPI = FB90DE40)
128 20:05:33.132 10/17/02 Sev=Info/5 IKE/0x63000017
Marking IKE SA for deletion (COOKIES = 728409A9FD9BC72A A3BDED35299E4E7E) reason = DEL_REASON_DONT_NOTIFY_CM
129 20:05:33.132 10/17/02 Sev=Info/4 IKE/0x63000013
SENDING >>> ISAKMP OAK INFO *(HASH, DEL) to 212.242.88.234
130 20:05:33.132 10/17/02 Sev=Info/4 CM/0x63100013
Phase 1 SA deleted cause by DEL_REASON_PEER_NOT_RESPONDING. 0 Phase 1 SA currently in the system
131 20:05:33.461 10/17/02 Sev=Info/5 CM/0x63100029
Initializing CVPNDrv
132 20:05:33.461 10/17/02 Sev=Info/4 CM/0x63100031
Resetting TCP connection on port 10000
133 20:05:33.461 10/17/02 Sev=Info/6 CM/0x63100034
Removed local TCP port 1037 for TCP connection.
134 20:05:33.461 10/17/02 Sev=Info/6 CM/0x63100035
Tunnel to headend device vpn.fgnet.dk disconnected: duration: 0 days 0:35:53
135 20:05:33.507 10/17/02 Sev=Info/4 IPSEC/0x63700013
Delete internal key with SPI=0xf883e6ee
136 20:05:33.507 10/17/02 Sev=Info/4 IPSEC/0x6370000C
Key deleted by SPI 0xf883e6ee
137 20:05:33.507 10/17/02 Sev=Info/4 IPSEC/0x63700013
Delete internal key with SPI=0xb829e314
Does any have a Idee of this problem. ?
Best regards
Sore Knudsen
skn@qualitynet.dk
Re: VPN 3015 consentrator to Clinet connection lost
We saw the same problem. The only way around it that we could see was to disable IKE keepalives for the group and then hope that the idle timeout will disconnect those clients that have been rudely dropped but are still listed. This has fixed most of the disconnects we were getting and I haven't had anymore complaints (we get ~25 users connected at any one time). I use it about every day and havew only been disconnected once in the last 2 months.
We figured that the IKE keepalive packets were getting lost or dropped when a dial up client was busy doing other things and had pretty much filled up its pipe. You may want to check the bandwidth on your internet connection as we had to upgrade from a T1 because of the number of Cable/DSL users working from home.
Thanx for the info
95
