05-12-2003
01:35 AM
- last edited on
02-21-2020
11:43 PM
by
cc_security_adm
What is the different berween Default gateway & Tunnel default gateway ?
05-12-2003 03:03 AM
The VPN 3000 needs to have a default Gateway normally to the internet. Maybe the clients (terminated VPN sessions on the concentrator) should have a default gateway to the internal network or somewhere else.
Thats it.
Markus
05-12-2003 05:27 PM
Just to clarify what the previous poster said, the default gateway is used by the concentrator to route packets usually to the Internet.
The TDG is used as a default gateway for any encrpyted traffic that comes in from clients, L2L tunnels, etc. You would only use the TDG if you have a router on the inside of your concentrator that connects to the rest of your internal network. You don't have to specify a TDG if you only have a flat network on the inside of the concentrator, or you can specify static routes for your internal networks pointing to the inside router also.
05-12-2003 11:29 PM
thanks a lot !
