Community Member
VPN 3030 load balancing
Has anyone done VPN 3000 load balancing? It seems pretty simple, but what I can't find in the documentation is whether you use the same group address pools on both concentrators, or if you need to use different address pools.
Thanks.
Re: VPN 3030 load balancing
You should be using different ip pools, and they should be different to yout private networks subnet. . This is to handle the routing issue.
You inside network should know which concentrator private address to send the reply packets to.
If you use DHCP to assign information, you can have a potentially smaller pool of addresses; but it may be simpler to allocate a separate pool from each of the 3000 concentrators - that way, you can also easily identify which unit they come in from (if you have need of that).
97
