VPN 3030 Sateful failover possible?
Dear all
We are looking at designing a fully redundant VPN solution consisting of two routers, two pix 515's, two vpn 3030's and two cat 4006 switches. The goal is to design a fully redundant IPSec VPN solution. Is it possible with the VPN 3030's to do stateful failover like you can on the PIX and if so what do you need and how does it work? Is there any sort of redundancy that can be done between two VPN 3030's?
Many thanks in advance.
1 REPLY
Re: VPN 3030 Sateful failover possible?
This would be great but the VPN 3000 only has the early generation failover mechanism in place. Hopefully stateful failover will be available in the future.
161
