Community Member
VPN 857W to Pix515 Problem
I've a Pix 515 with 10 VPN with 501 that works well.
I try to configure a 857W to do this and have some problem :
ISAKMP (0): Checking ISAKMP transform 1 against priority 20 policy
ISAKMP: encryption 3DES-CBC
ISAKMP: hash SHA
ISAKMP: default group 2
ISAKMP: auth pre-share
ISAKMP: life type in seconds
ISAKMP: life duration (VPI) of 0x0 0x1 0x51 0x80
ISAKMP (0): atts are not acceptable. Next payload is 3
ISAKMP (0): Checking ISAKMP transform 2 against priority 20 policy
ISAKMP: encryption DES-CBC
ISAKMP: hash MD5
ISAKMP: auth RSA sig
ISAKMP (0): Checking ISAKMP transform 3 against priority 20 policy
ISAKMP: hash SHA
ISAKMP: default group 1
ISAKMP (0): atts are not acceptable. Next payload is 0
ISAKMP (0): Checking ISAKMP transform 1 against priority 65535 policy
ISAKMP: hash SHA
ISAKMP (0): Checking ISAKMP transform 2 against priority 65535 policy
ISAKMP: hash MD5
ISAKMP (0): Checking ISAKMP transform 3 against priority 65535 policy
ISAKMP: hash SHA
ISAKMP (0): no offers accepted!
ISAKMP (0): SA not acceptable!
return status is IKMP_ERR_TRANS
Pix Config :
sysopt connection permit-ipsec
sysopt connection permit-l2tp
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto dynamic-map outside_dyn_map 20 match address outside_cryptomap_dyn_20
crypto dynamic-map outside_dyn_map 20 set transform-set ESP-DES-MD5
crypto dynamic-map outside_dyn_map 40 match address outside_cryptomap_dyn_40
crypto dynamic-map outside_dyn_map 40 set transform-set ESP-DES-MD5
crypto map outside_map_1 170 match address TOULOUSE-MAP
crypto map outside_map_1 170 set peer 81.x.x.x
crypto map outside_map_1 170 set transform-set ESP-DES-MD5
isakmp key ******** address 81.x.x.x netmask 255.255.255.255 no-xauth no-config-mode
isakmp policy 20 authentication pre-share
isakmp policy 20 encryption des
isakmp policy 20 hash md5
isakmp policy 20 group 2
isakmp policy 20 lifetime 86400
and the 857W :
crypto isakmp policy 2
hash md5
group 2
crypto isakmp key vpnkeyadministrat0r address 213.223.x.x
crypto ipsec transform-set ESD-DES-MD5 esp-des esp-md5-hmac
crypto map SDM_CMAP_1 1 ipsec-isakmp
description Tunnel to213.223.x.x
set peer 213.223.x.x
set transform-set ESD-DES-MD5
match address 101
1 REPLY
Re: VPN 857W to Pix515 Problem
You're failing ISAKMP because your proposals don't match. On the 837 do:
IOS routers (and PIX's for that matter) default to using certificates for Phase 1 authentication, so you have to actually tell them to use the pre-shared key.
220
