VPN and Split-DNS problem connecting 851 to 3030 Concentrator
I have configured a Cisco 851 (IOS 12.4(11)T) to connect to the Cisco 3000 Concentrator (v4.72G). I am having multiple problems:
1. On the concentrator I have specified multiple domain names for split DNS "hq.portablesunlimited.com,hq.cellfonestore.com". However I see only the first name created for the dns views.
2. We have a static WAN IP address with a fixed DNS Server name given by our ISP. I am using the same DNS name on the client PCs connected to the 851. I am able to resolve any external names for e.g. "www.google.com". When I try to resolve a DNS address (Split-DNS) for e.g. server.hq.portablesunlimited.com, it fails to resolve the address. I tried to specify the address of 815 (10.0.0.1) as the DNS server for the clients, in this case the clients do not resolve any address. However if I go to the 851 console and ping say "www.yahoo.com" it works and then I can resolve that address "www.yahoo.com" from the client PCs also.
I don't have any firewall or NAT enabled on the 851.
Here is the 851 config file:
version 12.4
no service pad
service password-encryption
hostname firewall
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
enable secret 5 xxxxxxxxxxxx
no aaa new-model
clock timezone PCTime -5
clock summer-time PCTime date Apr 6 2003 2:00 Oct 26 2003 2:00
no ip dhcp use vrf connected
ip dhcp excluded-address 10.220.1.1 10.220.1.99
ip dhcp excluded-address 10.220.1.201 10.220.1.254
ip dhcp pool sdm-pool1
import all
network 10.220.1.0 255.255.255.0
dns-server 129.x.x.80
default-router 10.220.1.1
ip cef
ip domain name mydomain.com
ip name-server 129.x.x.80
crypto pki trustpoint TP-self-signed-3072999871
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3072999871
revocation-check none
rsakeypair TP-self-signed-3072999871
crypto ipsec client ezvpn VPN1
connect auto
group xyz key xyz
mode network-extension
peer x.x.x.x
username xyz password xyz
xauth userid mode local
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
description $FW_OUTSIDE$$ES_WAN$
ip address 129.34.x.x.255.255.240
duplex auto
speed auto
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$$ES_LAN$$FW_INSIDE$
ip address 10.220.1.1 255.255.255.0
ip tcp adjust-mss 1452
crypto ipsec client ezvpn VPN1 inside
ip route 0.0.0.0 0.0.x.x.34.7.82
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip dns view ezvpn-internal-view
domain name-server 10.128.1.10
ip dns view-list ezvpn-internal-viewlist
view ezvpn-internal-view 10
restrict name-group 1
view default 20
ip dns name-list 1 permit HQ.PORTABLESUNLIMITED.COM
ip dns server view-group ezvpn-internal-viewlist
no cdp run
end
1 REPLY
Re: VPN and Split-DNS problem connecting 851 to 3030 Concentrato
Someone please reply to the post as this issue is critical for us to decide the purchase of the above equipment for our 40 remote locations.
Srikant
130
