VPN and XP Home Edition
I just recently installed a Cisco 3005 Series VPN. We currently have an NT domain at my main office. I use Windows XP Home edition at my home. I can connect to my office network thru the VPN tunnel. I can ping the machines on my office network. My problem is when I open up network neighborhood there is nothing there. Also when I use VNC, I have to put in an IP address instead of a machine name. We use WINS on our NT domain. Can anyone please help. Thanks.
  • Other Security Subjects
Re: VPN and XP Home Edition
On the VPN concentrator, under the users group, general tab, did you enable WINS and DNS? If no, add them (with server IPs) - this will enable WINS and DNS and will send this info (ie WINS server IP) to client.
Hope it helps.
Steve
One problem you might have is that Windows XP home edition can not participate in a domain. It is for workgroups only. Try the suggestion for configuring WINS in the TCP/IP properties, but if that doesn't work, you will have to use find machines by ip addresses.
also, what version of the client are you running? i had similar issues with the 3.5.3 and the 3.6 client with dsn. when i upgraded to the 3.6.1 client, the issues were gone.
Believe that you have not set up your WINS and DNS servers on the 3005 concentrator. The context on the concentrator is: Configuration | User Management | Groups. You should simply need to configure the General and IPSEC tabs.
our firm uses cisco 3015, nt doman and i use xp home edition at my home.. works fine.. including network neighborhood browsing and unc maps..
here's how we do it:
[on vpn concentrator]
group conguration (general tab) contains primary and secondary wins server ip addresses
user name and password combination same as nt domain user account (cisco vpn client passes username/pass to nt token)
[on xp home workstation]
on "control panel", "system" properties, "computer name" tab - workgroup name same as nt domain name
lmhosts file in c:\windows\system32\drivers\etc\ folder (should be same as the one on the pdc - if not, it must contain the pdc info for the nt domain)
tcp/ip properties "advanced" settings, "wins" tab - enable lmhosts lookup
that should do it.. like i indicated, mine works fine, with netbios name resolution - hope this helps
rob
Try changing the workgroup name on your home PC to match your office network's domain name. That has worked for me in the past.
102
