It is possible that your password was lost, overwritten, or typed incorrectly into your computer. If the Caps-lock key is on, you may have typed your password in capitol letters. Passwords are case-sensitive (it matters if the password is typed in capitol or lower-case letters. Check to make sure that you are typing the password in correctly. It is also possible that the Dial-In RAS domain is not set properly.
