Community Member
VPN between 2611XM and 1721 problems
I have 2611XM on a Central site and 1721 on a Remote site. I tried establish VPN between these sites but I couldn’t do that.
Here are config files:
Current configuration : 2706 bytes
version 12.2
hostname Cisco2611XM CENTRAL
enable secret xxxxx
enable password xxxx
username xxxx password 0 xxxxxxx
aaa new-model
aaa authentication login userauthen local
aaa authorization network groupauthor local
aaa session-id common
ip subnet-zero
ip audit notify log
ip audit po max-events 100
crypto isakmp policy 3
encr 3des
authentication pre-share
group 2
crypto isakmp policy 5
hash md5
crypto isakmp key xxxx address REMOTE PUBLIC IP no-xauth
crypto isakmp client configuration group xxxxxx
key xxxxx
dns 192.168.1.100
domain cpn.vwg
pool ippool
crypto ipsec transform-set myset esp-3des esp-sha-hmac
crypto ipsec transform-set myset1 esp-des esp-md5-hmac
crypto dynamic-map dynmap 10
set transform-set myset
crypto map clientmap client authentication list userauthen
crypto map clientmap isakmp authorization list groupauthor
crypto map clientmap client configuration address respond
crypto map clientmap 5 ipsec-isakmp
set peer REMOTE PUBLIC IP
set transform-set myset1
match address 115
crypto map clientmap 10 ipsec-isakmp dynamic dynmap
mta receive maximum-recipients 0
interface FastEthernet0/0
ip nat inside
no ip mroute-cache
speed auto
half-duplex
interface FastEthernet0/1
ip address CENTRAL PUBLIC IP 255.255.255.252
ip nat outside
no ip mroute-cache
duplex auto
speed auto
ip local pool ippool 10.1.1.100 10.1.1.200
ip nat pool internet CENTRAL PUBLIC IP CENTRAL PUBLIC IP prefix-length 30
ip nat inside source route-map nonat interface FastEthernet0/1 overload
ip classless
ip route 0.0.0.0 0.0.0.0 PROVIDER PUBLIC IP
ip route PRIVATE NETWORK 255.255.192.0 192.168.1.101
ip http server
ip access-list extended addr-pool
ip access-list extended dns-servers
ip access-list extended idletime
ip access-list extended inacl
ip access-list extended key-exchange
ip access-list extended protocol
ip access-list extended service
ip access-list extended tunnel-password
access-list 101 deny ip 192.168.1.0 0.0.0.255 192.168.0.0 0.0.0.255
access-list 101 deny ip 192.168.1.0 0.0.0.255 10.1.1.0 0.0.0.255
access-list 101 permit ip 192.168.1.0 0.0.0.255 any
access-list 115 permit ip 192.168.1.0 0.0.0.255 192.168.0.0 0.0.0.255
route-map nonat permit 10
match ip address 101
radius-server authorization permit missing Service-Type
call rsvp-sync
mgcp profile default
dial-peer cor custom
line con 0
line aux 0
line vty 0 4
password xxxxxx
end
Current configuration : 1393 bytes
version 12.2
service password-encryption
hostname 1721 REMOTE
logging queue-limit 100
memory-size iomem 25
ip subnet-zero
ip audit notify log
hash md5
crypto isakmp key xxxxx address CENTRAL PUBLIC IP no-xauth
crypto map test 5 ipsec-isakmp
set peer CENTRAL PUBLIC IP
match address 115
interface Ethernet0
ip address 192.168.0.1 255.255.255.0
no ip proxy-arp
ip nat inside
half-duplex
ip address REMOTE ADDRESS IP 255.255.255.252
no ip proxy-arp
ip nat outside
speed auto
crypto map test
ip nat inside source route-map nonat interface FastEthernet0 overload
ip classless
ip route 0.0.0.0 0.0.0.0 FastEthernet0
ip route PROVIDER PUBLIC NETWORK 255.255.255.252 FastEthernet0
no ip http server
no ip http secure-server
access-list 110 deny ip 192.168.0.0 0.0.0.255 192.168.1.0 0.0.0.255
access-list 110 permit ip 192.168.0.0 0.0.0.255 any
access-list 115 permit ip 192.168.0.0 0.0.0.255 192.168.1.0 0.0.0.255
match ip address 110
line con 0
line aux 0
line vty 0 4
password 7 xxxxxxx
login
no scheduler allocate
end
I cannot ping each other but clients I accept successfully. Are these config correct? PLS HELP
Community Member
Re: VPN between 2611XM and 1721 problems
Your configurations look ok, are you sending an extended ping from the router or a continous ping from a PC behind either router?
Is there a firewall in between this two peers?
Let us know
Arthur
Community Member
I sent ping from both routers, here are samples.
Cisco2611XM#ping
Protocol [ip]:
Target IP address: 192.168.0.1
Repeat count [5]: 10
Datagram size [100]:
Timeout in seconds [2]:
Extended commands [n]:
Sweep range of sizes [n]:
Sending 10, 100-byte ICMP Echos to 192.168.0.1, timeout is 2 seconds:
Success rate is 0 percent (0/10)
Cisco2611XM#traceroute 192.168.0.1
Tracing the route to 192.168.0.1
1 PROVIDER PUBLIC IP1 ADDRESS 28 msec 28 msec 28 msec
2 PROVIDER PUBLIC IP2 ADDRESS 28 msec 32 msec 28 msec
3 PROVIDER PUBLIC IP1 ADDRESS 32 msec 24 msec 28 msec
4 PROVIDER PUBLIC IP2 ADDRESS 28 msec 28 msec 28 msec
5 PROVIDER PUBLIC IP1 ADDRESS 33 msec 32 msec 28 msec
30. the same as above
This is from Cisco 2611XM CENTRAL OFFICE
Rodoc#ping
Protocol [ip]:
Target IP address: 192.168.1.1
Repeat count [5]:
Sending 5, 100-byte ICMP Echos to 192.168.1.1, timeout is 2 seconds:
Success rate is 0 percent (0/5)
cisco1721#traceroute 192.168.1.1
Tracing the route to 192.168.1.1
1 PROVIDER PUBLIC IP1 ADDRESS 0 msec 0 msec 0 msec
2 PROVIDER PUBLIC IP2 ADDRESS 36 msec 808 msec 212 msec
3 PROVIDER PUBLIC IP3 ADDRESS msec 32 msec 60 msec
4 PROVIDER PUBLIC IP4 ADDRESS 112 msec 700 msec 224 msec
5 PROVIDER PUBLIC IP5 ADDRESS 36 msec 100 msec 40 msec
6 * * *
This is from the Cisco 1721.
Provider are different.
I did not make any ping from local PC's on the LAN's, I've just tried from routers.
Community Member
the trace is showing a loop from the 2600 to the 1700 router
the reason being the IP1 and IP2 back and forth....
Can you ping the outside interfaces at all? public to public?
Community Member
I can ping from PC's on LAN 192.168.0.0 to PC's on LAN 192.168.1.0 but I cannot ping routers directly. I can ping public interfaces but cannot private interfaces.
125
