Community Member
VPN between ASA 5510 and Cisco 1721 router
Hi there,
I have a little problem. Advice me to resolve it pls.
I created IPSec VPN between ASA 5510 and Cisco 1721 and those config is following :
ASA 5510 configuration
interface Ethernet0/2
speed 100
duplex full
nameif inside
security-level 90
ip address 192.168.1.11 255.255.255.0
ospf cost 10
interface Ethernet0/3
speed 10
duplex full
nameif vpn
security-level 0
ip address 172.16.1.1 255.255.255.240
ospf cost 10
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
object-group service TCP_Service_Group tcp
description Well known TCP ports
port-object eq pop3
port-object eq sqlnet
port-object eq ftp-data
port-object eq ftp
port-object eq ssh
port-object eq telnet
port-object eq smtp
port-object eq https
port-object eq www
port-object eq domain
port-object range 5050 5050
port-object eq imap4
object-group service IPSec_Ports udp
port-object eq isakmp
object-group service vpn tcp
port-object range netbios-ssn netbios-ssn
port-object range 445 445
access-list inside_access_in extended permit ip any any
access-list inside_access_in extended permit ip 192.168.1.0 255.255.255.0 192.168.3.0 255.255.255.0
access-list inside_access_in extended permit tcp 192.168.1.0 255.255.255.0 192.168.3.0 255.255.255.0 object-group vpn
access-list inside_access_in extended permit tcp 192.168.1.0 255.255.255.0 any object-group TCP_Service_Group
access-list vpn_20_cryptomap extended permit ip 192.168.1.0 255.255.255.0 192.168.3.0 255.255.255.0
access-list inside_nat0_outbound extended permit ip 192.168.1.0 255.255.255.0 192.168.3.0 255.255.255.0
ip verify reverse-path interface outside
ip verify reverse-path interface dmz
ip verify reverse-path interface inside
ip verify reverse-path interface vpn
icmp unreachable rate-limit 1 burst-size 1
nat (inside) 0 access-list inside_nat0_outbound
nat (inside) 2 192.168.1.0 255.255.255.0
nat (vpn) 2 172.16.1.0 255.255.255.240
access-group inside_access_in in interface inside
route outside 0.0.0.0 0.0.0.0 x.x.x.x 1
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto map vpn_map 20 match address vpn_20_cryptomap
crypto map vpn_map 20 set peer 172.16.1.3
crypto map vpn_map 20 set transform-set ESP-3DES-SHA
crypto map vpn_map interface vpn
crypto isakmp enable vpn
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
tunnel-group 172.16.1.3 type ipsec-l2l
tunnel-group 172.16.1.3 ipsec-attributes
pre-shared-key *
Cisco 1721 routers configuration
crypto isakmp policy 11
encr 3des
group 2
crypto isakmp key cisco123 address 172.16.1.1
crypto ipsec transform-set 1st esp-3des esp-sha-hmac
crypto map nolan 11 ipsec-isakmp
set peer 172.16.1.1
set transform-set 1st
match address 120
interface Ethernet0
ip address 172.16.1.3 255.255.255.240
ip nat outside
full-duplex
crypto map nolan
interface FastEthernet0
ip address 192.168.3.1 255.255.255.0
ip nat inside
full-duplex
speed 100
ip nat pool branch 172.16.1.3 172.16.1.3 netmask 255.255.255.
ip nat inside source route-map nonat pool branch overload
ip route 0.0.0.0 0.0.0.0 172.16.1.1
access-list 120 permit ip 10.2.2.0 0.0.0.255 10.1.1.0 0.0.0.255
access-list 130 deny ip 10.2.2.0 0.0.0.255 10.1.1.0 0.0.0.255
access-list 130 permit ip 10.2.2.0 0.0.0.255 any
route-map nonat permit 10
match ip address 130
And now, I can access from 192.168.3.0/24 to any windows share in network 192.168.1.0/24 network like following:
Start\Run \\192.168.1.2
and also Internet access is OK.
And I can access to Internet from 192.168.1.0/24, but I can`t access to 192.168.3.0/24.
For example:
Start\Run \\192.168.3.2
Error is "The network path is not found."
__________
Is it clear?
where is problem? What should I do?
Help me pls,
Tnx a lot.
374
