06-24-2002 02:38 PM - edited 02-21-2020 11:49 AM
I need to configure a pix to create a vpn tunnel to a Checkpoint firewall. I have configured pix and when I ping from an inside host on the pix to a host on the dmz of CP FW I get MM_NO_STATE when I issue the cmd sh isakmp sa. PIX appears to initiate the vpn tunnel. Any advise.
06-24-2002 02:38 PM
need to turn on debug crytpo ipsec/isakmp/engine.
Also try the PIX tsa at :
http://te.cisco.com/SRVS/CGI-BIN/WEBCGI.EXE?New,KB=PIX,dtree=stepbystep
06-24-2002 07:49 PM
There's good sample configs for both the PIX and CheckPoint here:
http://www.cisco.com/warp/public/110/cp-p.html
If you follow this hen you should be good to go. If it still doesn't work, then as the previous response suggested, we'd need to see the "debug cry isa" and "debug cry sa" output. It's sounds like the PIX is maybe not getting a response from the CheckPoint to its tunnel request, so make sure you have UDP port 500 connectivity between the two devices.
