VPN Between Cisco 1750 to Netscreen 100
In the Past, I using two Cisco Router 1750 to form a VPN Channel ...
But Now I want to change using one Cisco Router and one Netscreen 100 to form a VPN,
What Config Should I need top take care and change
Sean Lai
1 REPLY
Re: VPN Between Cisco 1750 to Netscreen 100
Hi, I also want to set up a VPN between a Cisco Router and a NetScreen 500 through a frame relay cloud. Any advice would be very appreciated :)
Cheers
238
