VPN between Cisco 3660 and Linksys RV016
I set up a VPN between these two devices and it comes up OK, and stays up for a while...however, it justs drops for no reason. And just the interface (Tunnel6) goes down, the actual crypto session stays up. All I have to do is a "clear crypto session" and it comes back up OK, but I was curious if any of you have seen this before. I have turned on crypto ipsec error debugging, but I don't really get anything useful back. I get this occasionaly:
*Apr 2 08:17:05.123: %CRYPTO-4-PKT_REPLAY_ERR: decrypt: replay check failed
connection id=17, sequence number=633
But when I get this the connection stays up. When it drops I just get the message that says interface Tunnel6 has changed state from up to down. Here is piece of my config for the VPN in question:
crypto isakmp policy 1
encr 3des
hash md5
authentication pre-share
group 5
lifetime 3600
crypto isakmp key xxx address xx.xx.xxx.xxx no-xauth
crypto ipsec profile pro-link
set transform-set linksys
set pfs group5
interface Tunnel6
description VPN to Humphrey Terminal
ip address 10.10.61.2 255.255.255.0
keepalive 300 3
tunnel source FastEthernet0/0
tunnel destination xx.xx.xx.xx
tunnel mode ipsec ipv4
tunnel protection ipsec profile pro-link
ip route 192.168.210.0 255.255.255.0 Tunnel6
I can paste a screenshot of my linksys config too, if someone needs it. But I believe the trouble is on the cisco's end.
thanks!
Re: VPN between Cisco 3660 and Linksys RV016
I'll check this out, but this is the error I get when the connection drops:
*Apr 2 09:02:54.931: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel6, changed state to down
At this point the actual crypto session stays up, the router just won't pass any traffic over the tunnel interface as it thinks it is down. Thanks for the link though, I'll let you know if it clears up the other error.
Thanks for the help, but that didn't seem to work. It is definately more stable now, and I don't get the error about the replay window anymore. However the interface will still just drop for no reason while the crypto session stays up. In order to get this to work, I had to assign a ip address to the tunnel interface even though it doesn't use it for anything. Is that causing problems?
300
