VPN between Cisco and Checkpoint NG
Hi all
i'm using vpn between cisco routeur and checkpoint NG version me i'm in cisco side and there is an other who work with the checkpoint, rigth i'm doing the cisco configuration side as bellow:
version 12.3
service password-encryption
hostname ALLO-MAROC-INTERNET
enable secret xxxxxx
username ADMIN password xxxxxx
aaa new-model
aaa authentication login default local
aaa session-id common
ip subnet-zero
no ip domain lookup
ip audit notify log
ip audit po max-events 100
no ftp-server write-enable
crypto isakmp policy 1
encr 3des
hash md5
authentication pre-share
group 2
lifetime 1800
crypto isakmp key xxxx address 194.204.xxx.xx
crypto ipsec transform-set AlloSet esp-3des esp-md5-hmac
crypto map AlloMap 1 ipsec-isakmp
set peer 194.204.xxx.xx
set transform-set AlloSet
match address 100
interface FastEthernet0
ip address 62.251.xxx.x 255.255.255.240
speed auto
no cdp enable
interface Serial0
ip address 62.251.xxx.xx 255.255.255.252
no fair-queue
no cdp enable
crypto map AlloMap
ip classless
ip route 0.0.0.0 0.0.0.0 Serial0
no ip http server
no ip http secure-server
access-list 100 permit ip host 62.251.xxx.x host 10.128.66.11
access-list 100 permit ip host 62.251.xxx.x host 10.128.66.12
access-list 100 permit ip host 62.251.xxx.x host 10.128.66.13
no cdp run
radius-server authorization permit missing Service-Type
line con 0
line aux 0
line vty 0 4
no scheduler allocate
end
i send him all parametres that he need for doing the configuration from his side and i don't know if its all ok or no but i know that the checkpoint has an private address on his outside interface and there is an translation on an router between it and internet
so when i try to ping an machine on the checkpoint side and debuging the isakmp i have this log:
*Mar 1 02:08:13.707: ISAKMP: received ke message (1/1)
*Mar 1 02:08:13.707: ISAKMP (0:0): SA request profile is (NULL)
*Mar 1 02:08:13.707: ISAKMP: local port 500, remote port 500
*Mar 1 02:08:13.707: ISAKMP: set new node 0 to QM_IDLE
*Mar 1 02:08:13.707: ISAKMP: Find a dup sa in the avl tree during calling isadb_insert sa = 81E3FDDC
*Mar 1 02:08:13.707: ISAKMP (0:69): Can not start Aggressive mode, trying Main mode.
*Mar 1 02:08:13.711: ISAKMP: Looking for a matching key for 194.204.xxx.xx in default : success
*Mar 1 02:08:13.711: ISAKMP (0:69): found peer pre-shared key matching 194.204.xxx.xx
*Mar 1 02:08:13.711: ISAKMP (0:69): constructed NAT-T vendor-03 ID
*Mar 1 02:08:13.711: ISAKMP (0:69): constructed NAT-T vendor-02 ID
*Mar 1 02:08:13.711: ISAKMP (0:69): Input = IKE_MESG_FROM_IPSEC, IKE_SA_REQ_MM
*Mar 1 02:08:13.711: ISAKMP (0:69): Old State = IKE_READY New State = IKE_I_MM1
*Mar 1 02:08:13.711: ISAKMP (0:69): beginning Main Mode exchange
*Mar 1 02:08:13.711: ISAKMP (0:69): sending packet to 194.204.xxx.xx my_port 500 peer_port 500 (I) MM_NO_STATE
*Mar 1 02:08:23.711: ISAKMP (0:69): retransmitting phase 1 MM_NO_STATE...
*Mar 1 02:08:23.711: ISAKMP (0:69): incrementing error counter on sa: retransmit phase 1
*Mar 1 02:08:23.711: ISAKMP (0:69): sending packet to 194.204.xxx.xx my_port 500 peer_port 500 (I) MM_NO_STATE
*Mar 1 02:08:33.711: ISAKMP (0:69): retransmitting phase 1 MM_NO_STATE...
*Mar 1 02:08:33.711: ISAKMP (0:69): incrementing error counter on sa: retransmit phase 1
*Mar 1 02:08:33.711: ISAKMP (0:69): sending packet to 194.204.xxx.xx my_port 500 peer_port 500 (I) MM_NO_STATE
so as you see the 1st phase of ike still loop and i don't know why!
plese give me more help
regards
Bronze
Re: VPN between Cisco and Checkpoint NG
Take a look at the following URL as it shows the configuration steps for router to Checkpoint NG. http://www.cisco.com/en/US/tech/tk583/tk372/technologies_configuration_example09186a00800b4b40.shtml
I know this document and my configuration is true but there is some thing that i don't know at the checkpoint side i think there is some access-list and the gay don't remember them
please if you can help me for the debug output message because the cisco configuration side is ok
regards
The Access-List on your Side and the Encryption Domain on the CP-side have to be identical.
Ask the CP Admin what the Encryption Domain on the CP Side looks like.
It must match exactly.
What you can do, is to change your ACL to:
access-list 100 permit ip host 62.251.x.x 10.128.66.0 0.0.0.255.
On the CP side: Is your Gateway asscociated with the corresponding VPN definition? can you check this?
Hi ailmer
for the access-list there are same because CP side allow just the one host for testing (me i allow four hosts)
but i don't know what do you wan explain with the encryption domain on checkpoint!!
if you have any documents about this please send it to me selmrabet@cbi.ma
149
