04-06-2003 11:28 PM - edited 02-21-2020 12:27 PM
Im having a trouble in establishing vpn tunnel from cisco 1720 router having 12.5(4) ios to checkpoint firewall NG.Im pasting the debug output along with this mail.Teh debug messages shows problems in quick mode.Can anyone help me out.
rypto isakmp policy 5
hash md5
lifetime 86400
encryption des
authentication pre-share
group 2
crypto isakmp policy 10
hash md5
encryption des
lifetime 3600
crypto isakmp key xxxx address 81.144.129.210
crypto isakmp key xxxx address 0.0.0.0 0.0.0.0
crypto ipsec transform-set transform1 esp-des esp-md5-hmac
crypto dynamic-map laingmap 10
set transform-set transform1
match address 115
crypto map stlaingmap local-address Dialer1
crypto map stlaingmap 5 ipsec-isakmp
set peer 81.144.129.210
match address 110
crypto map stlaingmap 10 ipsec-isakmp dynamic laingmap
interface BRI0
description connected to Internet
bandwidth 68000
no ip address
ip nat outside
encapsulation ppp
no ip route-cache
no ip mroute-cache
dialer rotary-group 1
isdn switch-type basic-net3
no cdp enable
w3d: ISAKMP (0:1): beginning Main Mode exchange
w3d: ISAKMP (0:1): sending packet to 81.144.129.210 (I) MM_NO_STATE
w3d: ISAKMP (0:1): received packet from 81.144.129.210 (I) MM_NO_STATE
w3d: ISAKMP (0:1): processing SA payload. message ID = 0
w3d: ISAKMP (0:1): found peer pre-shared key matching 81.144.129.210
w3d: ISAKMP (0:1): Checking ISAKMP transform 1 against priority 5 policy
w3d: ISAKMP: encryption DES-CBC
w3d: ISAKMP: hash MD5
w3d: ISAKMP: default group 2
w3d: ISAKMP: auth pre-share
w3d: ISAKMP (0:1): atts are acceptable. Next payload is 0.
w3d: ISAKMP (0:1): SA is doing pre-shared key authentication using id type ID_I
V4_ADDR
w3d: ISAKMP (0:1): sending packet to 81.144.129.210 (I) MM_SA_SETUP
w3d: ISAKMP (0:1): received packet from 81.144.129.210 (I) MM_SA_SETUP
w3d: ISAKMP (0:1): processing KE payload. message ID = 0
w3d: ISAKMP (0:1): processing NONCE payload. message ID = 0
w3d: ISAKMP (0:1): SKEYID state generated
w3d: ISAKMP (1): ID payload
next-payload : 8
type : 1
protocol : 17
port : 500
length : 8
w3d: ISAKMP (1): Total payload length: 12
w3d: ISAKMP (0:1): sending packet to 81.144.129.210 (I) MM_KEY_EXCH
w3d: ISAKMP (0:1): received packet from 81.144.129.210 (I) MM_KEY_EXCH
w3d: ISAKMP (0:1): processing ID payload. message ID = 0
w3d: ISAKMP (0:1): processing HASH payload. message ID = 0
w3d: ISAKMP (0:1): SA has been authenticated with 81.144.129.210
w3d: ISAKMP (0:1): beginning Quick Mode exchange, M-ID of 794030509
w3d: ISAKMP (0:1): sending packet to 81.144.129.210 (I) QM_IDLE
w3d: ISAKMP (0:1): received packet from 81.144.129.210 (I) QM_IDLE
w3d: ISAKMP (0:1): phase 1 packet is a duplicate of a previous packet.
w3d: ISAKMP (0:1): retransmitting due to retransmit phase 1
w3d: ISAKMP (0:1): retransmitting phas.e 1 QM_IDLE ...
w3d: ISAKMP (0:1): retransmitting phase 1 QM_IDLE ...
w3d: ISAKMP (0:1): incrementing error counter on sa: retransmit phase 1
w3d: ISAKMP (0:1): no outgoing phase 1 packet to retransmit. QM_IDLE
w3d: ISAKMP (0:0): received packet from 81.144.129.210 (N) NEW SA
w3d: %CRYPTO-4-IKMP_NO_SA: IKE message from 81.144.129.210 has no SA and is no
an initialization offer...
uccess rate is 0 percent (0/5)
ainc-0014#
w3d: ISAKMP (0:1): retransmitting phase 2 QM_IDLE 794030509 ...
w3d: ISAKMP (0:1): incrementing error counter on sa: retransmit phase 2
w3d: ISAKMP (0:1): retransmitting phase 2 794030509 QM_IDLE
04-07-2003 08:09 PM
Checkpoint side is retransmitting IKE phase 1 packets, and IOS is complaining that it has already replied to it.
double check ur config :
http://www.cisco.com/warp/public/707/ipsec-checkpt.html
Thx
Afaq
