Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
vpn client 3.0.1 not able to connect to router 3640(configuration below)
I have installed vpn client 3.0.1 in windows 2000 proffesional pc and trying to make a secure connection to a cisco 3640 vpn enabled router IOs 12.2(8) .when i try to connect i get message"Failed to establish a secure connection to the security gateway."
My configuration is as below
crypto isakmp policy 20
encr 3des
hash md5
authentication pre-share
group 2
crypto isakmp client configuration group 3000client
key cisco123
pool ourpool
crypto ipsec transform-set vpnclient esp-3des esp-md5-hmac
crypto dynamic-map dynmap 10
set transform-set vpnclient
crypto map combined client configuration address initiate
crypto map combined client configuration address respond
crypto map combined 40 ipsec-isakmp dynamic dynmap
ip local pool ourpool 10.2.1.1 10.2.1.254
Any help would be highhly appreciated.
Thanks for fast responce
Re: vpn client 3.0.1 not able to connect to router 3640(configur
You're missing the authentication/authorization part of the confguration. Add the following:
> aaa new-model
> aaa authentication login userauthen group local
> aaa authorization network groupauthor local
> crypto map combined client authentication list userauthen
> crypto map combined isakmp authorization list groupauthor
Make sure the crypto map is applied to the outside interface.
See http://www.cisco.com/warp/public/480/ipsec-ios-tacacs.html for an example. Note this does TACACS user authentication, what I've shown above will do local user authentication, so you'll need to add:
> username password
commands onto the router for each user also.
Hi gfullage,
thanks for the reply.Now I am able to get a connection to the secure gateway.So the authentication is a important part in this configurtation.
tanweer@mdsuae.co.ae
85
