VPN Client 3.0.3 - connecting to Pix ; Compression
I would just like to know whether the integrated client supports compression to a pix and if so where i can find docs on it.. It seems as though compression is only supported to a concentrator..
thnks,
mike
1 REPLY
Re: VPN Client 3.0.3 - connecting to Pix ; Compression
I do not think the VPN client 3.x can be configed for compression in the PIX.
There is no command for that.
Altough the VPN accelerator card in the PIX support encrytption and compression.
In the VPN 3000 concentrator, there is a check box for that function. So the concentrator suppor that function.
79
