lkc
VPN Client 4 for Linux (Redhat) and connectivity issues
Hi all,
I've been playing around with the VPN Client for Linux (am running on a redhat 9).
The connection starts just fine and everything seems to work and i'm assigned a client ip address.
vpnclient stat show me that traffic is encrypted and that some are bypassed (i'm writing it right now with the client enabled. split-tunneling should be enabled which is ok).
for some reason all traffic is going the wrong way ? all traffic bypasses the vpn connection ?
Do i need to add some static routing on my Redhat ? or is it probably the split tunnelig which is wrong ?
The "vpnclient stat" tells me the following !
Configured routes.
Secured Network Destination Netmask
0.0.0.0 0.0.0.0
Local Network Destination Netmask
10.0.0.0 255.255.255.0
which looks ok ? (but apparantly i'm still bypassing the ipsec tunnel).
Can anyone help out here or give me a hint ?
Lasse
1 REPLY
Silver
Re: VPN Client 4 for Linux (Redhat) and connectivity issues
Can you provide more details like what is the equipment to which you are trying to connect on the otherside. Also the error message you are getting if any.
135
