VPN Client and Pix issue
I have a pix 501 that I am trying to configure for VPN Client access. I am trying to test the following config and it doesn't seem to want to authenticate. I am trying to connect from within the same network just to see if it will authenticate but it will not. I have also tried from work with the same results. Can someone tell me what I am missing? I have looked on many, many websites and can't find an answer. thanks in advance. Following is my config:
interface ethernet0 auto
interface ethernet1 100full
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password xxxxxx encrypted
passwd xxxxxx encrypted
hostname xxxx
domain-name xxxxxx.com
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol pptp 1723
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
access-list 100 permit tcp any any eq pptp
access-list 100 permit udp any any eq 1701
access-list 100 permit udp any any eq 4500
access-list 100 permit tcp any interface outside eq pptp
access-list 100 permit udp any any eq isakmp
access-list acl_out permit tcp any interface outside eq pptp
access-list acl_out permit gre any interface outside
pager lines 24
mtu outside 1500
mtu inside 1500
ip address outside dhcp setroute
ip address inside 10.99.99.1 255.255.0.0
ip audit info action alarm
ip audit attack action alarm
ip local pool ippool 10.99.99.30-10.99.99.100
pdm logging informational 100
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list 100
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
static (inside,outside) tcp interface pptp 10.99.99.0 pptp netmask 255.255.255.255 0 0
access-group 100 in interface outside
timeout xlate 0:05:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
http server enable
http 10.99.0.0 255.255.0.0 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
sysopt connection permit-ipsec
sysopt connection permit-pptp
sysopt connection permit-l2tp
crypto ipsec transform-set myset esp-des esp-md5-hmac
crypto dynamic-map dynmap 10 set transform-set myset
crypto map mymap 10 ipsec-isakmp dynamic dynmap
crypto map mymap client configuration address initiate
crypto map mymap client configuration address respond
crypto map mymap interface outside
isakmp enable outside
isakmp key ******** address 0.0.0.0 netmask 0.0.0.0
isakmp client configuration address-pool local ippool outside
isakmp policy 10 authentication rsa-sig
isakmp policy 10 encryption des
isakmp policy 10 hash sha
isakmp policy 10 group 1
isakmp policy 10 lifetime 86400
isakmp policy 20 authentication pre-share
isakmp policy 20 encryption des
isakmp policy 20 hash sha
isakmp policy 20 group 2
isakmp policy 20 lifetime 86400
vpngroup vpn3000-all idle-time 1800
vpngroup vpn3000 address-pool ippool
vpngroup vpn3000 default-domain xxxxxxxxxx
vpngroup vpn3000 idle-time 1800
vpngroup vpn3000 password ********
telnet 10.99.99.0 255.255.255.0 inside
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd address 10.99.99.2-10.99.99.33 inside
dhcpd lease 3600
dhcpd ping_timeout 750
dhcpd auto_config outside
dhcpd enable inside
terminal width 80
Gold
Re: VPN Client and Pix issue
Your configuration look a little messy, take a look at the following document on how to configure Client VPN access on a PIX.
http://www.cisco.com/en/US/tech/tk583/tk372/technologies_configuration_example09186a008009442e.shtml
The above configuration setup is on a PIX running 6.2(1) but if your PIX is running 6.3+,then I would suggest you enable NAT Traversal (NAT-T) for ISAKMP. To do this do (in config mode) :
isakmp nat-traversal
The above command will help when you initiate a VPN client connection from behind another NAT device.
Also, are you trying to allow PPTP & L2TP too? As you don't have the apporiate configuration configured.
I would suggest that you clean up your configuration and start with one service first i.e. VPN client access and then add any other service you require i.e. PPTP or L2TP - If you need help on this let me know. You can re-set your PIX to factory default by issuing:
(in config mode) configure factory-default
Now you can start afresh.
Hope this helps you.
Jay
Jay,
Thanks for the response. I went to the website that you had posted. I reset everything back to the defaults and modified the basic config to replicate the config on the website. I then tried to access the vpn via the client but still to no avail. I had to reset my config back to the original so that I can access the vpn for work. I'm still at a loss. I had l2tp and pptp added to my original config just to test other vpn connections but none of them seem to work. It looks like the vpn client is being rejected or the security gateway on the pix is not responding. Any ideas as to what could be causing this issue?
Thanks again for your help,
Shawn
97
