07-04-2008 09:28 AM - edited 02-21-2020 03:48 PM
I am attempting to setup a VPN connection on a new computer. This connection currently works fine on another machine. I have installed the Root Cert chain and my personal cert as before and it fails to connect. I have included my log file below. The cert shows as valid so I am unsure what I have done wrong. I have done this for other machines and it has worked fine. Any help would be appreciated!
Thank you
Karl
Cisco Systems VPN Client Version 4.8.01.0300
Copyright (C) 1998-2005 Cisco Systems, Inc. All Rights Reserved.
Client Type(s): Windows, WinNT
Running on: 5.1.2600 Service Pack 3
109 10:24:39.791 07/04/08 Sev=Info/6 CERT/0x63600025
Attempting to find a Certificate using Serial Hash.
110 10:24:39.791 07/04/08 Sev=Info/6 CERT/0x63600026
Found a Certificate using Serial Hash.
111 10:24:39.791 07/04/08 Sev=Info/6 CERT/0x63600025
112 10:24:39.791 07/04/08 Sev=Info/6 CERT/0x63600026
113 10:24:39.791 07/04/08 Sev=Info/6 CERT/0x63600025
114 10:24:39.791 07/04/08 Sev=Info/6 CERT/0x63600026
115 10:24:39.870 07/04/08 Sev=Info/4 CERT/0x63600015
Cert (cn=XXXXXXXXXXXXXX,ou=CSADMIN,dc=secure,dc=XXXXXXXXXXXX,dc=com) verification succeeded.
116 10:24:40.901 07/04/08 Sev=Info/6 CERT/0x63600025
117 10:24:40.901 07/04/08 Sev=Info/6 CERT/0x63600026
118 10:24:41.135 07/04/08 Sev=Info/4 CERT/0x6360001B
No smart card readers with cards inserted found.
119 10:24:41.432 07/04/08 Sev=Warning/2 CERT/0xE360003E
Cert chain missing or intermediate CA signature failed - Cert verification failed.
120 10:24:41.432 07/04/08 Sev=Warning/2 IKE/0xE3000097
Unable to validate peer certificate, Common Name co-sec-vpn01.ou=secure.ou=XXXXXXXXXXXX.o=com., Issuer cn=CPI,dc=secure,dc=XXXXXXXXXXX,dc=com, (CertCfg:241).
121 10:24:41.432 07/04/08 Sev=Warning/2 IKE/0xE300009B
Failed to process MM Msg 6 (NavigatorMM:570)
122 10:24:41.432 07/04/08 Sev=Warning/2 IKE/0xE30000A7
Unexpected SW error occurred while processing Identity Protection (Main Mode) negotiator:(Navigator:2237)
07-10-2008 06:32 AM
VPN connection was not established because of an unrecognized reason. Please check the logs for details. Better solution is Install an Identity Cert that is not chained.
