You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
VPN Client Connection Problem - The VPN Client could not find the adapters
VPN Client version - 4.6.01.0019
Problem : The VPN Client fails to establish a connection.
Details : The Cisco VPN Client fails to establish a connection and pops up the User Authentication Dialog repeatedly. I have tried with different MTU settings (1300, 1448) but it still does not work. The log file contents are as follows...
Cisco Systems VPN Client Version 4.6.01.0019
Copyright (C) 1998-2004 Cisco Systems, Inc. All Rights Reserved.
Client Type(s): Windows, WinNT
Running on: 5.0.2195 Service Pack 4
Config file directory: C:\Program Files\Cisco Systems\VPN Client
1 20:01:53.445 01/29/06 Sev=Warning/3 GUI/0xE3B00003
GI EnumPPP callback timed out.
2 20:05:23.797 01/29/06 Sev=Warning/2 CVPND/0xE3400014
The VPN Client could not find the adapters GUID - Virtual Adapter's tcpip GUID failed: 2.
3 20:05:23.797 01/29/06 Sev=Warning/3 CVPND/0xE340000D
The Client was unable to enable the Virtual Adapter because it could not set the IP configuration into the registry.
4 20:05:23.797 01/29/06 Sev=Warning/2 CM/0xE3100009
The virtual adapter failed to enable
5 20:05:23.797 01/29/06 Sev=Warning/2 IKE/0xE3000099
Failed to active IPSec SA: Unable to enable Virtual Adapter (NavigatorQM:936)
6 20:05:23.797 01/29/06 Sev=Warning/2 IKE/0xE30000A5
Unexpected SW error occurred while processing Quick Mode negotiator:(Navigator:2202)
  • Other Security Subjects
1 REPLY
Silver
Re: VPN Client Connection Problem - The VPN Client could not fin
Before adding or removing any network adapters from the Network Control Panel, uninstall the VPN Client, and reboot the computer. After the adapters are configured appropriately, reinstall the client. If this procedure is not followed you may experience system instability upon rebooting after adapters have been added or removed. You can recover by starting your Windows system in Safe Mode, uninstalling the client, rebooting, and then reinstalling the client.
4376
