VPN client connection
I have set up my 515 PIX and I would like to make connection VPN client
when I connection with VPN client, it show following error message and It can't make connection successfully. Would u help to solve problem?
1 13:00:29.910 04/30/02 Sev=Warning/3 IKE/0xA300004A
Received a NOTIFY message with an invalid protocol id (0)
nameif ethernet0 outside security0
nameif ethernet1 inside security100
nameif ethernet2 dmz security50
enable password mR4k9NNqlwc4Xar4 encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
hostname PIX
domain-name hk.tmsw.com
fixup protocol ftp 21
fixup protocol http 80
fixup protocol h323 1720
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol sip 5060
fixup protocol skinny 2000
names
access-list VPN permit ip 198.99.173.0 255.255.255.0 198.99.172.0 255.255.255.0
access-list VPN permit ip 198.99.173.0 255.255.255.0 198.99.180.0 255.255.255.0
access-list VPN permit ip 198.99.173.0 255.255.255.0 192.128.60.0 255.255.255.0
access-list VPN permit ip 198.99.173.0 255.255.255.0 198.99.170.0 255.255.255.0
access-list VPN permit ip 198.99.173.0 255.255.255.0 204.126.195.0 255.255.255.0
access-list VPN permit ip 198.99.173.0 255.255.255.0 1.1.1.0 255.255.255.0
access-list VPN permit ip 198.99.173.0 255.255.255.0 1.1.6.0 255.255.255.0
access-list VPN permit ip 198.99.173.0 255.255.255.0 1.1.10.0 255.255.255.0
access-list VPN permit ip 198.99.173.0 255.255.255.0 1.1.11.0 255.255.255.0
access-list VPN permit ip 198.99.173.0 255.255.255.0 1.1.2.0 255.255.255.0
access-list VPN permit ip 198.99.173.0 255.255.255.0 192.168.2.0 255.255.255.0
access-list VPN permit ip 198.99.173.0 255.255.255.0 192.168.8.0 255.255.255.0
access-list VPN permit ip 198.99.173.0 255.255.255.0 192.168.0.0 255.255.255.0
access-list Chicago permit ip 198.99.173.0 255.255.255.0 198.99.172.0 255.255.25
5.0
access-list Chicago permit ip 198.99.173.0 255.255.255.0 198.99.180.0 255.255.25
5.0
access-list Disney permit ip 198.99.173.0 255.255.255.0 host 192.128.60.115
access-list Miami permit ip 198.99.173.0 255.255.255.0 198.99.170.0 255.255.255.
access-list Toronto permit ip 198.99.173.0 255.255.255.0 204.126.195.0 255.255.2
55.0
access-list London permit ip 198.99.173.0 255.255.255.0 1.1.1.0 255.255.255.0
access-list London permit ip 198.99.173.0 255.255.255.0 1.1.6.0 255.255.255.0
access-list London permit ip 198.99.173.0 255.255.255.0 1.1.10.0 255.255.255.0
access-list London permit ip 198.99.173.0 255.255.255.0 1.1.11.0 255.255.255.0
access-list Leeds permit ip 198.99.173.0 255.255.255.0 1.1.2.0 255.255.255.0
access-list Sydney permit ip 198.99.173.0 255.255.255.0 192.168.0.0 255.255.255.
access-list Melbourne permit ip 198.99.173.0 255.255.255.0 192.168.8.0 255.255.2
55.0
access-list vpnremote permit ip 198.99.173.0 255.255.255.0 10.1.1.0 255.255.255.
pager lines 24
interface ethernet0 auto
interface ethernet1 auto
interface ethernet2 auto shutdown
mtu outside 1500
mtu inside 1500
mtu dmz 1500
ip address outside 202.130.186.114 255.255.255.240
ip address inside 198.99.173.2 255.255.255.0
ip address dmz 127.0.0.1 255.255.255.255
ip audit info action alarm
ip audit attack action alarm
ip local pool bigpool 10.1.1.101-10.1.1.102
no failover
failover timeout 0:00:00
failover poll 15
failover ip address outside 0.0.0.0
failover ip address inside 0.0.0.0
failover ip address dmz 0.0.0.0
pdm history enable
arp timeout 604800
nat (inside) 0 access-list VPN
nat (inside) 0 198.99.173.0 255.255.255.0 0 0
conduit permit tcp any any
conduit permit udp any any
conduit permit icmp any any
route outside 0.0.0.0 0.0.0.0 202.130.186.113 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h323 0:05:00 si
p 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
http 192.168.100.30 255.255.255.255 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
sysopt connection permit-ipsec
no sysopt route dnat
crypto ipsec transform-set common esp-des esp-sha-hmac
crypto dynamic-map dynamp 10 set transform-set common
crypto map tmsw 10 ipsec-isakmp
crypto map tmsw 10 match address Chicago
crypto map tmsw 10 set peer 204.233.233.18
crypto map tmsw 10 set transform-set common
crypto map tmsw 20 ipsec-isakmp
crypto map tmsw 20 match address Miami
crypto map tmsw 20 set peer 157.238.182.50
crypto map tmsw 20 set transform-set common
crypto map tmsw 30 ipsec-isakmp
crypto map tmsw 30 match address Toronto
crypto map tmsw 30 set peer 207.35.192.2
crypto map tmsw 30 set transform-set common
crypto map tmsw 40 ipsec-isakmp
crypto map tmsw 40 match address London
crypto map tmsw 40 set peer 195.74.151.253
crypto map tmsw 40 set transform-set common
crypto map tmsw 50 ipsec-isakmp
crypto map tmsw 50 match address Leeds
crypto map tmsw 50 set peer 212.58.55.253
crypto map tmsw 50 set transform-set common
crypto map tmsw 60 ipsec-isakmp
crypto map tmsw 60 match address Sydney
crypto map tmsw 60 set peer 203.202.137.130
crypto map tmsw 60 set transform-set common
crypto map tmsw 70 ipsec-isakmp
crypto map tmsw 70 match address Melbourne
crypto map tmsw 70 set peer 203.202.137.186
crypto map tmsw 70 set transform-set common
crypto map tmsw client configuration address initiate
crypto map tmsw client configuration address respond
crypto map tmsw interface outside
isakmp enable outside
isakmp key ******** address 204.233.233.18 netmask 255.255.255.255
isakmp key ******** address 157.238.182.50 netmask 255.255.255.255
isakmp key ******** address 207.35.192.2 netmask 255.255.255.255
isakmp key ******** address 195.74.151.253 netmask 255.255.255.255
isakmp key ******** address 212.58.55.253 netmask 255.255.255.255
isakmp key ******** address 203.202.137.130 netmask 255.255.255.255
isakmp key ******** address 203.202.137.186 netmask 255.255.255.255
isakmp client configuration address-pool local bigpool outside
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption des
isakmp policy 10 hash sha
isakmp policy 10 group 1
isakmp policy 10 lifetime 86400
isakmp policy 30 authentication pre-share
isakmp policy 30 encryption des
isakmp policy 30 hash sha
isakmp policy 30 group 2
isakmp policy 30 lifetime 86400
vpngroup IT address-pool bigpool
vpngroup IT dns-server 198.99.173.32
vpngroup IT default-domain tmsw
vpngroup IT idle-time 86400
vpngroup IT password ********
Re: VPN client connection
You seem to be missing the dynamic statment on your tmsw crypto map:
You can use what ever sequence number you like... 100 is just an example.
"crypto map tmsw 100 ipsec-isakmp dynamic dynamp"
You also will need to add the bigpool address-space to the nat 0 access-list
"access-list VPN permit ip 198.99.173.0 255.255.255.0 10.1.1.101 255.255.255.255"
"access-list VPN permit ip 198.99.173.0 255.255.255.0 10.1.1.102 255.255.255.255"
These statments are not needed if you are using VPN 3000 or Unified 3.X client
Only for IRE client 1.0 1.1 client (i.e. Cisco Secure VPN Client)
thank you for your much
You give a very good solution to help me to fix the problem
I would like to ask one more question
After form VPN channel, Can I still access other web (www.yahoo.com)?
I found that after the channel, i only can access my intranet only
Thank you for your help
You will need to add a command to your vpngroup configuration.
"vpngroup IT split-tunnel vpnremote"
This will match traffic on the remote client side that is to be encrypted and all other traffic with a destination other than your internal network will not be processed by ipsec.
You seemed to already have the correct access-list in your config for this...
access-list vpnremote permit ip 198.99.173.0 255.255.255.0 10.1.1.0 255.255.255.0
Please let me know if this helps.
Jason Parrish
jparrish@rightsys.com
Thank you for your help!!
I can access internet even form VPN channel
But isn't/aren't pre-shared key(s) for the dynamic VPN clients missing? There are pre-shared keys for the static peers but I can't see one for the dynamic VPN clients.
97
