VPN Client Connectivity Problems
I am trying to connect to our network via VPN 3000 Client Dialer. I have no problems connecting from any location except for one site. And I can take the same equipment from the one site and it will work at any other site so I believe my problem is site specific and not a concentrator or software problem.
The only site specific items are a DSL connection through Verizon and the ISP .
One workstation cannot connect at all. The other workstation gets a connection only about 75% of the time.
I can get onto the internet on both workstations without a problem. I can always ping the VPN server.
I've tried changing the MTU down to as low as 300. My connection is through a Fujitsu speedport DSL modem. I do use a Linksys BEFSR41 router, but I have the same problems when I connect directly from the DSL modem.
I've used my log viewer and filtered the IKE to high.
The following is the log on a good connection:
1 13:54:30.075 06/11/02 Sev=Info/6 IKE/0x6300003B
Attempting to establish a connection with 64.65.113.146.
2 13:54:30.135 06/11/02 Sev=Info/4 IKE/0x63000013
SENDING >>> ISAKMP OAK AG (SA, KE, NON, ID, VID, VID, VID) to 64.65.113.146
3 13:54:30.405 06/11/02 Sev=Info/5 IKE/0x6300002F
Received ISAKMP packet: peer = 64.65.113.146
4 13:54:30.405 06/11/02 Sev=Info/4 IKE/0x63000014
RECEIVING <<< ISAKMP OAK AG (SA, VID, VID, VID, KE, ID, NON, HASH) from 64.65.113.146
5 13:54:30.405 06/11/02 Sev=Info/5 IKE/0x63000059
Vendor ID payload = 12F5F28C457168A9702D9FE274CC0100
6 13:54:30.405 06/11/02 Sev=Info/5 IKE/0x63000001
Peer is a Cisco-Unity compliant peer
7 13:54:30.405 06/11/02 Sev=Info/5 IKE/0x63000059
Vendor ID payload = AFCAD71368A1F1C96B8696FC77570100
8 13:54:30.405 06/11/02 Sev=Info/5 IKE/0x63000001
Peer supports DPD
9 13:54:30.405 06/11/02 Sev=Info/5 IKE/0x63000059
Vendor ID payload = CFE5E554E5BA09A82BF49BB3FC2A434B
10 13:54:30.425 06/11/02 Sev=Info/4 IKE/0x63000013
SENDING >>> ISAKMP OAK AG *(HASH, NOTIFY:STATUS_INITIAL_CONTACT) to 64.65.113.146
11 13:54:33.459 06/11/02 Sev=Info/5 IKE/0x6300002F
12 13:54:33.459 06/11/02 Sev=Info/4 IKE/0x63000014
RECEIVING <<< ISAKMP OAK INFO *(HASH, NOTIFY:STATUS_RESP_LIFETIME) from 64.65.113.146
13 13:54:33.459 06/11/02 Sev=Info/5 IKE/0x63000044
RESPONDER-LIFETIME notify has value of 86400 seconds
14 13:54:33.459 06/11/02 Sev=Info/5 IKE/0x63000046
This SA has already been alive for 3 seconds, setting expiry to 86397 seconds from now
15 13:54:33.459 06/11/02 Sev=Info/5 IKE/0x6300002F
16 13:54:33.459 06/11/02 Sev=Info/4 IKE/0x63000014
RECEIVING <<< ISAKMP OAK TRANS *(HASH, ATTR) from 64.65.113.146
17 13:54:38.476 06/11/02 Sev=Info/4 IKE/0x63000013
SENDING >>> ISAKMP OAK TRANS *(HASH, ATTR) to 64.65.113.146
18 13:54:38.816 06/11/02 Sev=Info/5 IKE/0x6300002F
19 13:54:38.816 06/11/02 Sev=Info/4 IKE/0x63000014
20 13:54:38.826 06/11/02 Sev=Info/4 IKE/0x63000013
21 13:54:38.917 06/11/02 Sev=Info/5 IKE/0x6300005D
Client sending a firewall request to concentrator
22 13:54:38.917 06/11/02 Sev=Info/5 IKE/0x6300005C
Firewall Policy: Product=Cisco Integrated Client, Capability= (Centralized Policy Push).
23 13:54:38.917 06/11/02 Sev=Info/4 IKE/0x63000013
24 13:54:39.117 06/11/02 Sev=Info/5 IKE/0x6300002F
25 13:54:39.117 06/11/02 Sev=Info/4 IKE/0x63000014
26 13:54:39.117 06/11/02 Sev=Info/5 IKE/0x63000010
MODE_CFG_REPLY: Attribute = INTERNAL_IPV4_ADDRESS: , value = 192.168.2.9
27 13:54:39.117 06/11/02 Sev=Info/5 IKE/0x63000010
MODE_CFG_REPLY: Attribute = INTERNAL_IPV4_DNS(1): , value = 192.168.1.11
28 13:54:39.117 06/11/02 Sev=Info/5 IKE/0x63000010
MODE_CFG_REPLY: Attribute = INTERNAL_IPV4_DNS(2): , value = 192.168.1.13
29 13:54:39.117 06/11/02 Sev=Info/5 IKE/0x6300000E
MODE_CFG_REPLY: Attribute = MODECFG_UNITY_DEFDOMAIN: , value = aritapoulson.com
30 13:54:39.117 06/11/02 Sev=Info/5 IKE/0x6300000D
MODE_CFG_REPLY: Attribute = MODECFG_UNITY_SPLIT_INCLUDE (# of split_nets), value = 0x00000001
31 13:54:39.117 06/11/02 Sev=Info/5 IKE/0x6300000F
SPLIT_NET #1
subnet = 192.168.1.0
mask = 255.255.255.0
protocol = 0
src port = 0
dest port=0
32 13:54:39.137 06/11/02 Sev=Info/5 IKE/0x63000055
Received a key request from Driver for IP address 64.65.113.146, GW IP = 64.65.113.146
33 13:54:39.137 06/11/02 Sev=Info/4 IKE/0x63000013
SENDING >>> ISAKMP OAK QM *(HASH, SA, NON, ID, ID) to 64.65.113.146
34 13:54:40.238 06/11/02 Sev=Info/5 IKE/0x6300002F
35 13:54:40.238 06/11/02 Sev=Info/4 IKE/0x63000014
RECEIVING <<< ISAKMP OAK QM *(HASH, SA, NON, ID, ID, NOTIFY:STATUS_RESP_LIFETIME) from 64.65.113.146
36 13:54:40.238 06/11/02 Sev=Info/5 IKE/0x63000044
RESPONDER-LIFETIME notify has value of 28800 seconds
37 13:54:40.238 06/11/02 Sev=Info/5 IKE/0x63000045
RESPONDER-LIFETIME notify has value of 4608000 kb
38 13:54:40.238 06/11/02 Sev=Info/4 IKE/0x63000013
SENDING >>> ISAKMP OAK QM *(HASH) to 64.65.113.146
39 13:54:40.238 06/11/02 Sev=Info/5 IKE/0x63000058
Loading IPsec SA (Message ID = 0x634A97CD OUTBOUND SPI = 0x48109C01 INBOUND SPI = 0x1A37E4EC)
40 13:54:40.238 06/11/02 Sev=Info/5 IKE/0x63000025
Loaded OUTBOUND ESP SPI: 0x48109C01
41 13:54:40.238 06/11/02 Sev=Info/5 IKE/0x63000026
Loaded INBOUND ESP SPI: 0x1A37E4EC
42 13:54:40.579 06/11/02 Sev=Info/5 IKE/0x63000055
Received a key request from Driver for IP address 192.168.1.11, GW IP = 64.65.113.146
43 13:54:40.579 06/11/02 Sev=Info/4 IKE/0x63000013
44 13:54:44.284 06/11/02 Sev=Info/5 IKE/0x6300002F
45 13:54:44.284 06/11/02 Sev=Info/4 IKE/0x63000014
46 13:54:44.284 06/11/02 Sev=Info/5 IKE/0x63000044
47 13:54:44.284 06/11/02 Sev=Info/5 IKE/0x63000045
48 13:54:44.284 06/11/02 Sev=Info/4 IKE/0x63000013
49 13:54:44.284 06/11/02 Sev=Info/5 IKE/0x63000058
Loading IPsec SA (Message ID = 0x75B7F909 OUTBOUND SPI = 0xA3D4CF8E INBOUND SPI = 0xB89A1AAB)
50 13:54:44.284 06/11/02 Sev=Info/5 IKE/0x63000025
Loaded OUTBOUND ESP SPI: 0xA3D4CF8E
51 13:54:44.284 06/11/02 Sev=Info/5 IKE/0x63000026
Loaded INBOUND ESP SPI: 0xB89A1AAB
52 13:54:48.930 06/11/02 Sev=Info/5 IKE/0x6300002F
53 13:54:48.930 06/11/02 Sev=Info/4 IKE/0x63000014
RECEIVING <<< ISAKMP OAK INFO *(HASH, NOTIFY:INVALID_SPI) from 64.65.113.146
54 13:54:48.930 06/11/02 Sev=Info/5 IKE/0x63000018
Deleting IPsec SA: (OUTBOUND SPI = A3D4CF8E INBOUND SPI = B89A1AAB)
55 13:54:49.311 06/11/02 Sev=Info/5 IKE/0x63000055
56 13:54:49.311 06/11/02 Sev=Info/4 IKE/0x63000013
57 13:54:50.562 06/11/02 Sev=Info/5 IKE/0x6300002F
58 13:54:50.562 06/11/02 Sev=Info/4 IKE/0x63000014
59 13:54:50.562 06/11/02 Sev=Info/5 IKE/0x63000044
60 13:54:50.562 06/11/02 Sev=Info/5 IKE/0x63000045
61 13:54:50.562 06/11/02 Sev=Info/4 IKE/0x63000013
62 13:54:50.562 06/11/02 Sev=Info/5 IKE/0x63000058
Loading IPsec SA (Message ID = 0x4B5752BD OUTBOUND SPI = 0xF4753EF8 INBOUND SPI = 0x79BE5B87)
63 13:54:50.562 06/11/02 Sev=Info/5 IKE/0x63000025
Loaded OUTBOUND ESP SPI: 0xF4753EF8
64 13:54:50.562 06/11/02 Sev=Info/5 IKE/0x63000026
Loaded INBOUND ESP SPI: 0x79BE5B87
65 13:54:54.377 06/11/02 Sev=Info/6 IKE/0x6300003D
Sending DPD request to 64.65.113.146, seq# = 1852414286
66 13:54:54.377 06/11/02 Sev=Info/4 IKE/0x63000013
SENDING >>> ISAKMP OAK INFO *(HASH, NOTIFY:DPD_REQUEST) to 64.65.113.146
67 13:54:55.258 06/11/02 Sev=Info/5 IKE/0x6300002F
68 13:54:55.258 06/11/02 Sev=Info/4 IKE/0x63000014
RECEIVING <<< ISAKMP OAK INFO *(HASH, NOTIFY:DPD_ACK) from 64.65.113.146
69 13:54:55.258 06/11/02 Sev=Info/5 IKE/0x6300003F
Received DPD ACK from 64.65.113.146, seq# received = 1852414286, seq# expected = 1852414286
70 14:00:26.422 06/11/02 Sev=Info/6 IKE/0x6300003D
Sending DPD request to 64.65.113.146, seq# = 1852414287
71 14:00:26.422 06/11/02 Sev=Info/4 IKE/0x63000013
72 14:00:26.462 06/11/02 Sev=Info/5 IKE/0x6300002F
73 14:00:26.462 06/11/02 Sev=Info/4 IKE/0x63000014
74 14:00:26.462 06/11/02 Sev=Info/5 IKE/0x6300003F
Received DPD ACK from 64.65.113.146, seq# received = 1852414287, seq# expected = 1852414287
75 14:08:30.079 06/11/02 Sev=Info/5 IKE/0x6300002F
76 14:08:30.079 06/11/02 Sev=Info/4 IKE/0x63000014
77 14:08:30.079 06/11/02 Sev=Info/4 IKE/0x63000057
Received an ISAKMP message for a non-active SA
78 14:08:35.076 06/11/02 Sev=Info/5 IKE/0x6300002F
79 14:08:35.076 06/11/02 Sev=Info/4 IKE/0x63000014
80 14:08:35.076 06/11/02 Sev=Info/4 IKE/0x63000057
81 14:08:49.295 06/11/02 Sev=Info/5 IKE/0x6300002F
82 14:08:49.295 06/11/02 Sev=Info/4 IKE/0x63000014
83 14:08:49.295 06/11/02 Sev=Info/4 IKE/0x63000057
84 14:08:52.279 06/11/02 Sev=Info/5 IKE/0x6300002F
85 14:08:52.279 06/11/02 Sev=Info/4 IKE/0x63000014
86 14:08:52.279 06/11/02 Sev=Info/4 IKE/0x63000057
87 14:09:04.345 06/11/02 Sev=Info/5 IKE/0x6300002F
88 14:09:04.345 06/11/02 Sev=Info/4 IKE/0x63000014
89 14:09:04.345 06/11/02 Sev=Info/4 IKE/0x63000057
90 14:09:07.319 06/11/02 Sev=Info/5 IKE/0x6300002F
91 14:09:07.319 06/11/02 Sev=Info/4 IKE/0x63000014
92 14:09:07.319 06/11/02 Sev=Info/4 IKE/0x63000057
93 14:15:31.893 06/11/02 Sev=Info/5 IKE/0x6300002F
94 14:15:31.893 06/11/02 Sev=Info/4 IKE/0x63000014
RECEIVING <<< ISAKMP OAK INFO *(HASH, NOTIFY:DPD_REQUEST) from 64.65.113.146
95 14:15:31.893 06/11/02 Sev=Info/5 IKE/0x63000040
Received DPD request from 64.65.113.146, new seq# = 611704812, last seq# = 0
96 14:15:31.893 06/11/02 Sev=Info/6 IKE/0x6300003E
Sending DPD ACK to 64.65.113.146, seq# = 611704812
97 14:15:31.893 06/11/02 Sev=Info/4 IKE/0x63000013
SENDING >>> ISAKMP OAK INFO *(HASH, NOTIFY:DPD_ACK) to 64.65.113.146
98 14:20:32.265 06/11/02 Sev=Info/5 IKE/0x6300002F
99 14:20:32.265 06/11/02 Sev=Info/4 IKE/0x63000014
100 14:20:32.265 06/11/02 Sev=Info/5 IKE/0x63000040
Received DPD request from 64.65.113.146, new seq# = 611704813, last seq# = 611704812
101 14:20:32.265 06/11/02 Sev=Info/6 IKE/0x6300003E
Sending DPD ACK to 64.65.113.146, seq# = 611704813
102 14:20:32.265 06/11/02 Sev=Info/4 IKE/0x63000013
When I can't connect I get either a "CM peer not responding" after an "exceeded 3 IKE SA negotiation retransmits"
Any help would be greatly appreciated.
Re: VPN Client Connectivity Problems
Sounds to me like you have a signaling problem with the ISP, though the trace looks relatively clean. The fact you can take the same equipment to another site and it works well solidifies this. Definitely make sure you don’t have some sort of layer 2 issues at your local DSLAM, which can cause all sorts of anomalies.
I am not exactly aware of how you are connecting to the intenet and re-distributing it over your LAN , one thing i can say ..
Since you are using a DSL modem to connect to the ISP it gets one public IP address (correct me i i am wrong ) this is probaly NAT ed into your private IP address. if your DSL modem does not support NAT ing then this public IP address can be assigned to one internal IP and the moment the second user connects the first user shall be disconnected.
How are the other locations connected. .... ?
can contact me at gouthamb@hotmail.com
Cheers,
360
