VPN Client fails 3.6.3 on W98, W95 but works fine on NT, W2k and XP
I have tested my VPN connetion but my W98 and W95 Clients keep failing
Im using a W98SE client connected with dial-up networking and VPN.
My NT,W2k, and XP clients connect fine using dial-up networking and VPN.
The log viewer displays the folowing:
1 12:48:01.000 09/26/02 Sev=Warning/2 IKE/0xE300007C
Exceeded 3 IKE SA negotiation retransmits... peer is not responding
2 12:48:01.110 09/26/02 Sev=Warning/3 DIALER/0xE3300008
GI VPNStart callback failed "CM_PEER_NOT_RESPONDING" (16h).
All MS updates are done on the Client,
And client settings are default (just like W2k, and it works for w2k)
Who knows what is wrong with my W98 configuration !!!!!
Steve
  • Other Security Subjects
Bronze
Re: VPN Client fails 3.6.3 on W98, W95 but works fine on NT, W2k
client is not listening anything back from the concentrator, do u have any personal fw softaware installed on these PCs?
what abt the concentarator side logs?
Thx
Afaq
nope its a new and clean w95 w98 install.
but i foundout something more.
the w98 client works when i use my home network to connect to the internet
NAT router with DSL connection.
but doesnt when i use the dialup connection
Steve
I am having this same problem descibe above. VPN Client on Win98 will not connect through dialup but connects using DSL or any dedicated internet connection. Win2K are working fine using either connection.
Anyone with solution?
87
