vpn client lan connection problem
I have a vpn client connecting to a pix 515e , i get a vpn connection no problem but cannot ping anything on the internal network.
the local pool is 192.168.1.170-192.168.1.185 and the inside ip address of the pix is 192.168.1.10
any ideas ?
Re: vpn client lan connection problem
Could be something like your no-nat access list. Could you post your config so we can sanity check it? Don't forget to w.x.y.z the external ip addresses & xxx over your passwords :-)
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol ils 389
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
names
access-list vpn_to_belfast permit ip 192.168.1.0 255.255.255.0 192.168.2.0 255.2
55.255.0
access-list vpn_to_belfast permit icmp any any
access-list vpn_to_belfast permit icmp any any echo
access-list vpn_to_belfast permit icmp any any echo-reply
pager lines 24
logging on
mtu outside 1500
mtu inside 1500
mtu intf2 1500
ip address outside x.x.x.x y.y.y.y
ip address inside 192.168.1.10 255.255.255.0
no ip address intf2
ip audit info action alarm
ip audit attack action alarm
ip local pool jlsremote 192.168.1.171-192.168.1.185
pdm history enable
arp timeout 14400
nat (inside) 0 access-list vpn_to_belfast
access-group vpn_to_belfast in interface outside
route outside 0.0.0.0 0.0.0.0 x.x.x.x
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
sysopt connection permit-ipsec
crypto ipsec transform-set myset esp-3des esp-md5-hmac
crypto dynamic-map cisco 1 set transform-set myset
crypto map dyn-map 20 ipsec-isakmp dynamic cisco
crypto map dyn-map interface outside
isakmp enable outside
isakmp key ******** address 0.0.0.0 netmask 0.0.0.0
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption 3des
isakmp policy 10 hash md5
isakmp policy 10 group 1
isakmp policy 10 lifetime 3600
isakmp policy 20 authentication pre-share
isakmp policy 20 encryption 3des
isakmp policy 20 hash md5
isakmp policy 20 group 2
isakmp policy 20 lifetime 86400
vpngroup vpn3000 address-pool jlsremote
vpngroup vpn3000 default-domain xx
vpngroup vpn3000 idle-time 1800
vpngroup vpn3000 password xxxx
vpngroup dns-server idle-time 1800
please see my config ,
we have a pix to pix vpn as well on this, hence the vpn_to_belfast access-lists as well.
intf2 is going to be used for internet access outbound where as ethernet0 is going to be used for vpn tunnel from pix to pix and also vpn clients version 4 coming in over this interface..
any ideas ?
Your remote pool is from the same IP network than your internal interface, so you have to add the static for this pool going to outside or (recomanded) change the pool to some other IP network - 192.168.3.x.
As for using one interface for internet and second for VPN, is your client connecting from the same Public IP? Than this is possible, otherwise not.
Daniel
I have tried changing my local pool to 192.168.3.1-192.168.3.15.
and also added a static route to get to 192.168.3.0 255.255.255.0 go to the next hop but I am still being able to connect via the vpn but cannot ping anything on the inside network.
the vpn client is not using the same public ip address as the vpn tunnel, the clients will be accessing from home the vpn but the other vpn tunnel we are using is from a remote site.
any other ideas ?
What is the default gateway for the clients in internal network? Pix or router?
Daniel
the vpn client is set up to access the pix which has a direct connection out to a broadband box.
the vpn client gets connected but no traffic is passed.
i have a default route in the pix to say to get to anywhere go to the next hop which is the broadband managed box
when i dial in and get connected via vpn client, the gateway is itself by the look of it.
I have tried to add a static route into the pix to say to get to 192.168.3.0 go to the next hop as well.
no joy
any ideas
103
