VPN Client Limited to specific source addresses
We would like to limit which IP (public) addresses can establish an IPSec tunnel to our network.
One reason (to help clarify) - if a laptop is stolen and the password is discovered - you still must have a certain IP address or subnet for the tunnel to be established.
Thanks in advance for your help.
Gold
Re: VPN Client Limited to specific source addresses
have all the mobile user got a static ip when they are out of office?
mobile users often use modem dialup and then connect to the pix via the software client. if that's the case, then you can't really restrict the source address since you don't know what ip address is going to assign to the laptop.
We are restrictive in allowing VPN - so the user basically has to tell us what the IP address is. We don't have alot of mobile users - but we do have vendors who VPN in. Those VPN's for vendors is where we get very restrictive...or would like to be (on their source address).
FYI - we are doing this with a ChkPt firewall - but are trying to migrate from it.
Thanks for your time.
R
In order to improve your security you could install Radius or Tacacs authentication services in order to give each VPN user an ID and password. This way, no matter if laptop is stolen, if user don´t have correct ID and password, won´t be able to open the tunnel.
Check this for more information:
http://www.cisco.com/en/US/products/sw/secursw/ps2120/products_user_guide_chapter09186a0080106f8b.html
97
