VPN Client PC does not get assigned IP, can not communicate with LAN
We are using a Cisco PIX 506 running PIX Version 6.2(1)
We have installed Cisco Secure VPN Client 1.1 on a couple of laptops with same result.
When we connect to the internet and the vpn client session starts to access the local network, we get a request for username and password, the authentication works and the client is assigned an IP Address from the vpn-pool (you can see it on the client log and on the pix debug screens), but it all stops there.
The Client (laptop) does not recognize the new assigned IP address, therefore there is no IP route to the network and I can not ping anything via the VPN client. Using the ipconfig or the route print commands on the client reveal no new assigned address.
Here is the config of our PIX
solaintl(config)# show conf
: Saved
: Written by enable_15 at 10:26:51.753 UTC Wed Jun 26 2002
PIX Version 6.2(1)
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password ry.BJEjQAchWMHYi encrypted
passwd zEnA/ZabsT5E/MmK encrypted
hostname solaintl
fixup protocol ftp 21
fixup protocol http 80
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol ils 389
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol sip 5060
fixup protocol skinny 2000
names
access-list 80 permit ip 10.1.160.0 255.255.255.0 10.1.161.0 255.255.255.0
access-list 80 permit tcp 10.1.160.0 255.255.255.0 10.1.161.0 255.255.255.0
pager lines 24
logging on
interface ethernet0 10baset
interface ethernet1 10baset
mtu outside 1500
mtu inside 1500
ip address outside 12.105.233.236 255.255.255.240
ip address inside 10.1.160.3 255.255.248.0
ip audit info action alarm
ip audit attack action alarm
ip local pool vpn-pool 10.1.161.2-10.1.161.25
pdm history enable
arp timeout 14400
nat (inside) 0 access-list 80
static (inside,outside) 12.105.233.236 10.1.160.3 netmask 255.255.255.255 0 0
static (inside,outside) 12.105.233.238 10.1.160.55 netmask 255.255.255.255 0 0
static (inside,outside) 12.105.233.237 10.1.160.51 netmask 255.255.255.255 0 0
route outside 0.0.0.0 0.0.0.0 12.105.233.225 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h323 0:05:00 si
p 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ (inside) host 10.1.160.54 sicxxxxxx timeout 5
aaa-server RADIUS protocol radius
aaa-server RADIUS (inside) host 10.1.160.54 sicxxxxxx timeout 5
aaa-server LOCAL protocol local
aaa-server partnerauth protocol radius
aaa-server partnerauth (inside) host 10.1.160.54 sicxxxxxx timeout 5
aaa-server tacacs+ protocol tacacs+
aaa-server tacacs+ (outside) host 10.1.160.54 sicxxxxxx timeout 5
aaa-server radius protocol tacacs+
aaa-server radius (outside) host 10.1.160.54 sicxxxxxx timeout 5
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
no floodguard enable
sysopt connection permit-ipsec
no sysopt route dnat
crypto ipsec transform-set strong-des esp-des esp-md5-hmac
crypto dynamic-map cisco 8 set transform-set strong-des
crypto map partner-map 8 ipsec-isakmp dynamic cisco
crypto map partner-map client configuration address initiate
crypto map partner-map client configuration address respond
crypto map partner-map client authentication partnerauth
crypto map partner-map interface outside
isakmp enable outside
isakmp key ******** address 0.0.0.0 netmask 0.0.0.0
isakmp identity address
isakmp client configuration address-pool local vpn-pool outside
isakmp policy 8 authentication pre-share
isakmp policy 8 encryption des
isakmp policy 8 hash md5
isakmp policy 8 group 1
isakmp policy 8 lifetime 86400
vpngroup sola address-pool vpn-pool
vpngroup sola wins-server 10.1.160.51
vpngroup sola split-tunnel 80
vpngroup sola idle-time 1800
vpngroup sola password ********
telnet 10.1.160.0 255.255.248.0 inside
telnet timeout 10
ssh timeout 5
vpdn username administrator password ********
vpdn username corpvpn password ********
vpdn enable outside
terminal width 80
Cryptochecksum:fb73631ae7d85c5964500851c423839e
Here are the results of show crypto map and show crypto ipsec sa
solaintl(config)# show crypto map
Crypto Map: "partner-map" interfaces: { outside }
Crypto Map "partner-map" 8 ipsec-isakmp
Dynamic map template tag: cisco
Crypto Map "partner-map" 10 ipsec-isakmp
Peer = 32.101.185.217
access-list dynacl16; 1 elements
access-list dynacl16 (3) permit ip host 12.105.233.236 host 10.1.161.2
(id=20) (refcnt=2) (hitcnt=0)
dynamic (created from dynamic map cisco/8)
Current peer: 32.101.185.217
Security association lifetime: 4608000 kilobytes/28800 seconds
PFS (Y/N): N
Transform sets={ strong-des, }
solaintl(config)# show crypto ipsec sa
interface: outside
Crypto map tag: partner-map, local addr. 12.105.233.236
local ident (addr/mask/prot/port): (12.105.233.236/255.255.255.255/0/0)
remote ident (addr/mask/prot/port): (10.1.161.2/255.255.255.255/0/0)
current_peer: 32.101.185.217
dynamic allocated peer ip: 10.1.161.2
PERMIT, flags={}
#pkts encaps: 3, #pkts encrypt: 3, #pkts digest 3
#pkts decaps: 0, #pkts decrypt: 0, #pkts verify 0
#pkts compressed: 0, #pkts decompressed: 0
#pkts not compressed: 0, #pkts compr. failed: 0, #pkts decompress failed: 0
#send errors 0, #recv errors 0
local crypto endpt.: 12.105.233.236, remote crypto endpt.: 32.101.185.217
path mtu 1500, ipsec overhead 56, media mtu 1500
current outbound spi: 162a9f3b
inbound esp sas:
spi: 0x30ca868d(818579085)
transform: esp-des esp-md5-hmac ,
in use settings ={Tunnel, }
slot: 0, conn id: 1, crypto map: partner-map
sa timing: remaining key lifetime (k/sec): (4608000/27987)
IV size: 8 bytes
replay detection support: Y
inbound ah sas:
inbound pcp sas:
outbound esp sas:
spi: 0x162a9f3b(371892027)
slot: 0, conn id: 2, crypto map: partner-map
sa timing: remaining key lifetime (k/sec): (4607999/27951)
IV size: 8 bytes
outbound ah sas:
outbound pcp sas:
Thank you for your help!
Silver
Re: VPN Client PC does not get assigned IP, can not communicate
The details of the client connection only show up on the log, not on the command ipconfig. So tthat is not an issue.
The configuration of the pix looks correct, and if the debugs on the client stop, then it tends to mean that the client has connected succesfully.
It would take about 2 pings, before you get success on a ping to the network behind the pix. the other issue is wether the pc's behind the pix has default gateway set to the inside of the pix.
you could also do debug icmp trace on the pix, and trace the ping from the client to see if it gets to the pix, and where it stops.
Otherwise, you might want to consider opening a case with Cisco TAC for the issue
I have checked the configuration in your PIX as well as the debug information, the remote access VPN tunnel has been built up and the ip address has been assinged to the client.
There is three encryptions but no decryptions. That means there is routing issues in the client PC.
For The VPN client 1.1 or even 3.x, the ip address assinged from the VPN server will not showed up in the "IPCONFIG" command. from the Client debug, you will see the ip address has been assigned or not.
Sometimes, protocol IPSEC has been blocked will cause you same problem.
Because UDP 500 (ISAKMP) is not blocked, so you can pass authentication and get connection, but not pinging anything.
Use another dial up account from another ISP or directly plug a PC to the PIX outside interface and do a quick test, I think you might be able ping the inside net work.
Thank you both for your help.
It is my first setup of VPN with Cisco Hardware/Software and only have done it with Microsoft products, that's why I kept looking for ipconfig and ip routes.
I have to say that all our servers have a gateway that point at the CISCO router managing our WAN; but now that you mention this, I will add a static route on the servers where we need access to send all trafic for 10.1.161.0 to the internal ip of the PIX... That might be an issue...
I will also try all that has been suggested.
icmp tracing
alternative isp and direct connection to the PIX
I will do all of this tomorrow (Thursday morning), Because dinner awaits!
Thank you!
I have added static routes to our servers for 10.1.161.0 (the vpn-pool) but I may have a funamental routing problem at the pix and or the client... nothing pings nothing!
Inside or Outside, real IP or assigned IP...
Do you think mine is a problem outside the VPN settings?
Look at this session, I connected the client and then set to debug pings, but again, nothing pings nothing:
solaintl(config)# debug icmp trace
ICMP trace on
Warning: this may cause problems on busy networks
Peer = 129.37.43.148
access-list dynacl18; 1 elements
access-list dynacl18 (3) permit ip host 12.105.233.236 host 10.1.161.2
(id=24) (refcnt=2) (hitcnt=3)
Current peer: 129.37.43.148
PFS (Y/N): N
solaintl(config)#
solaintl(config)# ping outside 10.1.161.2
10.1.161.2 NO response received -- 1000ms
solaintl(config)# ping inside 10.1.161.2
solaintl(config)# ping 10.1.161.2
solaintl(config)# ping 129.37.43.148
129.37.43.148 NO response received -- 1000ms
solaintl(config)# ping inside 12.105.233.236
12.105.233.236 NO response received -- 1000ms
solaintl(config)# ping outside 10.1.160.3
10.1.160.3 NO response received -- 1000ms
solaintl(config)#
BTW I have opened a case with CISCO. The Engineer is now researching the problem...
Thanks for your help!
I noticed that you are running 6.2 try loading the new PDM 2.0. There is a built in wizard that will greatly reduce your time in trying to figure this out.
Thank you!
We've learn a lot in the last 2 weeks! I was expecting to see the assigned IP address using IPConfig and that is not the case.
We also had errors on our configuration of the Cisco Secure VPN Client.
A Cisco Engineer walked us through the settings for the IP Subnet and Tunnel and it started working.
I will research PDM 2.0 to see if we can benefit from it!
Thanks Again!
117
