Community Member
VPN CLIENT PROBLEM PIX V7.0(2)
I have a pix into V7.0(2) with a vpn client in 4.7.
The configuration is:
group-policy clientgroup internal
group-policy clientgroup attributes
vpn-idle-timeout 30
crypto ipsec transform-set myset esp-des esp-sha-hmac
crypto dynamic-map cisco 1 set transform-set myset
crypto dynamic-map cisco 1 set nat-t-disable
crypto map dyn-map 20 ipsec-isakmp dynamic cisco
crypto map dyn-map interface outside
isakmp enable outside
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption des
isakmp policy 10 hash sha
isakmp policy 10 group 2
isakmp policy 10 lifetime 86400
tunnel-group office type ipsec-ra
tunnel-group office general-attributes
address-pool vpn
authentication-server-group none
default-group-policy clientgroup
tunnel-group office ipsec-attributes
pre-shared-key ******
I have this error message on the pix:
[IKEv1]: Group = office, IP = 83.xx.xx.xx, Removing p
eer from peer table failed, no match!
Nov 22 08:52:52 [IKEv1]: Group = office, IP = 83.xx.xx.xx, Error: Unable to rem
ove PeerTblEntry
It is necessary that I add this: isakmp identity?
thank you for your reponses
Re: VPN CLIENT PROBLEM PIX V7.0(2)
hi
AFAIK isakmp identity is reqd if u have got 2 pix firewalls establshing the VPN connection between them.
you should also have this in ur easyvpn server when ur having a pix firewall as an easyvpn client.
the identity is basically exchanged between the peers during the IKE negotiations.
But i dont think its reqd to be keyed in while having VPN client s/w as ur clients..
did u try with that command keyed in the config ??
Also can you try using up with isakmp identity address instead of isakmp identity ??
regds
Community Member
Thanks, i'll try tomorrow.
106
