02-03-2006 02:03 PM - edited 02-21-2020 02:14 PM
Hi all,
I need support.
I use Cisco Vpn Client Ver.4.06, I select "Allow local LAN Access" but only traffic directed to remote LAN is permitted.
Ho to improve split-tunnell?
Where can I find any example?
Tks all.
02-03-2006 03:42 PM
Hello
Well the split tunneling option is usually configured on the VPN termination device is PIX or concentrator where the policy is pushed to the vpn client. Usually when setting up the split tunneling option you will have an access-lists matching destinations to be encrypted defined if it's not defined all traffic is encypted and sent to the vpn endpoint.
PIX Example:
LAN 192.168.1.0 255.255.255.0
vpngroup vpn-group split-tunnel vpn-group_splitTunnelAcl
access-list vpn-group_splitTunnelAcl permit ip 192.168.0.0 255.255.255.0 any
So if you have control of that then you should be able to change the vpn policy.
Patrick
02-03-2006 03:50 PM
spilt tunneling needs to be configured on the vpn server.
please advise what sort of device it is for further assistance.
