Vpn client to 2611 ISO vpn connection need help troubleshooting
Hi, Have been trying to set up a Cisco VPN client 4.x to a IOS vpn connection(C2600-IK8O3S-M). I believe it can be don but I am having troubles find the problem.
I have turned on debugging. Here is a sample of the debug from the router. Any assistance would be great appreciated.
Here is what I am debugging
General OS:
TACACS access control debugging is on
AAA Authentication debugging is on
AAA Authorization debugging is on
Cryptographic Subsystem:
Crypto ISAKMP debugging is on
Crypto Engine debugging is on
Crypto IPSEC debugging is on
Start of debug (edited...)
ISAKMP (0:0): received packet from 66.183.231.233 (N) NEW SA
ISAKMP: local port 500, remote port 500
ISAKMP: Created a peer node for 66.183.231.233
ISAKMP (0:1): Setting client config settings 82C7CAFC
ISAKMP (0:1): (Re)Setting client xauth list userauthen and state
ISAKMP: Locking CONFIG struct 0x82C7CAFC from crypto_ikmp_config_initi
alize_sa, count 1
ISAKMP (0:1): processing SA payload. message ID = 0
ISAKMP (0:1): processing ID payload. message ID = 0
ISAKMP (0:1): processing vendor id payload
ISAKMP (0:1): vendor ID seems Unity/DPD but bad major
ISAKMP (0:1): vendor ID is XAUTH
ISAKMP (0:1): vendor ID is DPD
ISAKMP (
edge-ro#0:1): vendor ID seems Unity/DPD but bad major
ISAKMP (0:1): vendor ID is Unity
ISAKMP (0:1): Checking ISAKMP transform 1 against priority 3 policy
ISAKMP: encryption... What? 7?
ISAKMP: hash SHA
ISAKMP: default group 2
ISAKMP: auth XAUTHInitPreShared
ISAKMP: life type in seconds
ISAKMP: life duration (VPI) of 0x0 0x20 0xC4 0x9B
ISAKMP: attribute 14
ISAKMP (0:1): Encryption algorithm offered does not match policy!
ISAKMP (0:1): atts are not acceptable. Next payload is 3
ISAKMP (0:1): Checking ISAKMP transform 1 against priority 65535 policy
ISAKMP: hash SHA
ISAKMP (0:1): Checking ISAKMP transform 2 against priority 65535 policy
ISAKMP: encryption DES-CBC
ISAKMP: hash MD5
ISAKMP: auth pre-share
ISAKMP (0:1): Hash algorithm offered does not match policy!
ISAKMP (0:1): atts are not acceptable. Next payload is 0
ISAKMP (0:1): no offers accepted!
ISAKMP (0:1): phase 1 SA not acceptable!
ISAKMP (0:1): incrementing error counter on sa: construct_fail_ag_init
ISAKMP (0:1): Unknown Input: state = IKE_READY, major, minor = IKE_MES
G_FROM_PEER, IKE_AM_EXCH
%CRYPTO-6-IKMP_MODE_FAILURE: Processing of Aggressive mode failed with
peer at 66.183.231.233
ISAKMP (0:1): received packet from 66.183.231.233 (R) AG_NO_STATE
ISAKMP (0:1): phase 1 packet is a duplicate of a previous packet.
ISAKMP (0:1): retransmitting due to retransmit phase 1
ISAKMP (0:1): retransmitting phase 1 AG_NO_STATE...
ISAKMP (0:1): incrementing error counter on sa: retransmit phase 1
ISAKMP (0:1): sending packet to 66.183.231.233 (R) AG_NO_STATE
ISAKMP (0:1): no outgoing phase 1 packet to retransmit. AG_NO_STATE
ISAKMP: quick mode timer expired.
ISAKMP (0:1): peer does not do paranoid keepalives.
ISAKMP (0:1): deleting SA reason "QM_TIMER expired" state (R) AG_NO_ST
ATE (peer 66.183.231.233) input queue 0
ISAKMP (0:1): Input = IKE_MESG_INTERNAL, IKE_PHASE1_DEL
ISAKMP (0:1): Old State = IKE_READY New State = IKE_DEST_SA
ISAKMP (0:1): purging SA., sa=82C7B864, delme=82C7B864
ISAKMP: Unlocking CONFIG struct 0x82C7CAFC on return of attributes, co
unt 0
CryptoEngine0: delete connection 1
Re: Vpn client to 2611 ISO vpn connection need help troubleshoot
This is your problem:
You're not even getting past Phase 1, which means your ISAKMP policy in the router is not correct. Make sure you have "group 2" defined under it cause the VPN client uses DH Group 2.
There's a sample config here:
http://www.cisco.com/en/US/products/sw/secursw/ps2308/products_configuration_example09186a00801c4246.shtml
Thanks for replying DFullage.
I am new to ipsec and Cisco routers but I believe I have the DH group 2 setting correctly in my config file. I have a problem when trying to configure the encr setting: crypto isakmp policy 3. I am only offered des under the encr section and not 3des. I believe this has something to do with the IOS version I am running, but I am not sure
If you could please look at my config I would appreacte it.
start of config
Current configuration : 4431 bytes
! Last configuration change at 13:26:38 Pacfic Sat Jan 17 2004
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname edge-ro
aaa new-model
aaa authentication login userauthen group tacacs+
aaa authorization network groupauthor local
aaa accounting exec default start-stop group tacacs+
aaa accounting commands 1 default stop-only group tacacs+
aaa accounting commands 15 default stop-only group tacacs+
aaa accounting network default start-stop group tacacs+
aaa accounting connection default start-stop group tacacs+
aaa accounting system default stop-only group tacacs+
aaa session-id common
enable secret 5 ######################
enable password 7 ######################
username john password 7 ######################
clock timezone Pacfic -8
clock summer-time pst recurring
ip subnet-zero
no ip source-route
no ip bootp server
ip audit notify log
ip audit po max-events 100
ip ssh authentication-retries 4
authentication pre-share
group 2
crypto isakmp client configuration group vpngroup
key palmason
dns 192.168.1.2
domain mydomain.com
pool ippool
crypto ipsec transform-set myset esp-des esp-sha-hmac
crypto dynamic-map dynmap 10
set transform-set myset
crypto map clientmap client authentication list userauthen
crypto map clientmap isakmp authorization list groupauthor
crypto map clientmap client configuration address respond
crypto map clientmap 10 ipsec-isakmp dynamic dynmap
voice call carrier capacity active
mta receive maximum-recipients 0
interface Ethernet0/0
ip address dhcp
ip access-group 101 in
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
no ip mroute-cache
full-duplex
no cdp enable
interface Ethernet0/1
ip address 172.16.0.1 255.255.0.0
ip nat inside
full-duplex
no cdp enable
ip local pool ippool 172.16.0.20 172.16.0.30
ip nat inside source list 15 interface Ethernet0/0 overload
ip classless
no ip http server
logging 192.168.1.50
access-list 15 permit 172.16.0.0 0.0.255.255
access-list 76 permit any log
access-list 101 permit tcp host 209.139.248.100 66.183.239.0 0.0.0.255 eq 22 log
access-list 101 permit tcp host 66.183.231.233 66.183.239.0 0.0.0.255 eq 22 log
access-list 101 permit icmp host 209.139.248.100 66.183.239.0 0.0.0.255 log
access-list 101 permit icmp host 66.183.231.233 66.183.239.0 0.0.0.255 log
access-list 101 deny icmp any any log
access-list 101 deny udp any any eq snmp log
access-list 101 deny ip 127.0.0.0 0.255.255.255 any log
access-list 101 deny ip 255.0.0.0 0.255.255.255 any log
access-list 101 deny ip 224.0.0.0 7.255.255.255 any log
access-list 101 deny ip host 0.0.0.0 any log
access-list 101 permit ip any any log
no cdp run
tacacs-server host 192.168.1.2 single-connection
tacacs-server key ########
call rsvp-sync
mgcp profile default
dial-peer cor custom
banner exec ^CWelcome, you have connected to router $(hostname).$(domain).^C
line con 0
exec-timeout 20 0
logging synchronous
line aux 0
exec-timeout 20 0
logging synchronous
line vty 0 4
location Victoria
access-class 76 in
exec-timeout 20 0
logging synchronous
transport input telnet
ntp clock-period 17208459
ntp server 140.142.16.34
end
Hello john,
I had faced a similar problem.
You can try these :
Under your crypto policy add
hash md5
your transform set should be like this
crypto ipsec transform-set myset esp-des esp-md5-hmac
HOPE THIS SOLVES YOUR PROBLEM
M.Radhakrishnan mrk@thehindu.co.in
Thanks M, Radhakrishnan, I will try this later today and let you know if it helps.
Thank you for responding.
John P
217
