Community Member
VPN Client to PIX issue
I've configured my PIX (506 with 6.1 ver) to terminate a client vpn tunnel(3.5).
This is the configuration of ipsec:
access-list nonat permit ip host 10.10.10.1 host 2.2.2.1
ip local pool ip-client 2.2.2.1-2.2.2.5
nat (inside) 0 access-list nonat
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server partnerauth protocol radius
aaa-server partnerauth (inside) host 10.10.10.10 system timeout 10
sysopt connection permit-ipsec
crypto ipsec transform-set myset esp-des esp-md5-hmac
crypto dynamic-map paperino 40 set transform-set myset
crypto map pippo 40 ipsec-isakmp dynamic paperino
crypto map pippo client authentication partnerauth
crypto map pippo interface outside
isakmp enable outside
isakmp policy 40 authentication pre-share
isakmp policy 40 encryption des
isakmp policy 40 hash md5
isakmp policy 40 group 2
isakmp policy 40 lifetime 86400
vpngroup superteam address-pool ip-client
vpngroup superteam idle-time 1800
vpngroup superteam password ********
But I'd like that who are connected to my network can only see one service on this server.
I've tryed various ways but I cannot specify a service on the nonat access-list and on dynamic-map match address... because don't work!
Can anyone help me?
thanks a lot.
Graziano.
Bronze
Re: VPN Client to PIX issue
what you can do is remove the sysopt command:
no sysopt connection permit-ipsec '
and then add the conduit/ACL for the VPN client address getting access to that particular server/service
Hope that helps
Jazib
Community Member
Thanks but...
How can I configure these ACL?
The packets incoming from outside are IPsec packets with the destination IP address the Ip of the outside interface of the PIX ? ? ? ?
If I don't use the sysopt I must permit the protcol number 50 and 51 and the udp port 500 but after... how can I restrict the visibilty of some service to my internal server?
thanks,
GRAZ.
Bronze
you don't have to permit protocol 50 or UDP port 500
Those packets would be allowed in to the pix whether you have sysopt enabled or disabled
Once you have the sysopt command off, then modify your ACL like this:
access-list outbound_in permit ip < private destination network >
access-list outbound_in permit ip 2.2.2.0 255.255.255.248 10.10.10.0 255.255.255.0
Hope that helps
Jazib
95
