VPN client to PIX520 via DSL using PPPoE
I've got a WIN2000 system I'm trying to VPN into a PIX520 over a DSL line that uses PPPoE (EnterNet 300 is the PPPoe client). I can connect to the Internet using the PPPoE client. Then I start the VPN client. I connect to the inside network- I can ping any inside address by IP address or by name. But I cannot browse the NT domain. If I take the same PC and connect it to a straight DHCP network, I connect the VPN client and everything works. I can browse the entire domain.
Any ideas?
Frank Murray, CCNP
1 REPLY
Re: VPN client to PIX520 via DSL using PPPoE
This is a common Problem of WIN2000 with RASPPOE, Enternet and others...
Try CFOS instead of Enternet300, this will work with Win2000. When using 'Start before logon' don't forget to insert the cfos ppoe-driver under 'Application Launcher.
Ulrich
181
