VPN client to site connection
bill_baxter
I receive this error message in ASDM when a VPN client tries to connect.
Group = DefaultRAGroup, IP = x.x.x.x, Error: Unable to remove PeerTblEntry
Group = DefaultRAGroup, IP = x.x.x.x, Removing peer from peer table failed, no match!
I have created a tunnel group called VPNTunnel, but the connection seems to be trying to use the DefaultRAGroup.
For the client config, what should i have in the name and password field for group authentication? I think this is where my proglem lies.
Thanks, Bill
8 Replies 8
andrew.prince
Level 10
Level 10
Bill,
Can you post your config - sanitised of course?
Andrew, here is the config.
Thanks, Bill
: Saved
ASA Version 7.2(3)
hostname DPPASA5505
domain-name .com
enable password xxx
names
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
ip address x.x.x.x 255.255.255.0
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
shutdown
interface Ethernet0/3
shutdown
interface Ethernet0/4
shutdown
interface Ethernet0/5
shutdown
interface Ethernet0/6
shutdown
interface Ethernet0/7
shutdown
passwd xxx
ftp mode passive
dns server-group DefaultDNS
domain-name .com
access-list VPNTunnel_splitTunnelAcl standard permit 192.168.1.0 255.255.255.0
access-list inside_nat0_outbound extended permit ip 192.168.1.0 255.255.255.0 192.168.1.224 255.255.255.224
pager lines 24
logging enable
logging asdm informational
mtu inside 1500
mtu outside 1500
ip local pool VPNPool 192.168.1.231-192.168.1.250 mask 255.255.255.0
no failover
monitor-interface inside
monitor-interface outside
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-523.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list inside_nat0_outbound
nat (inside) 1 0.0.0.0 0.0.0.0
route outside 0.0.0.0 0.0.0.0 x.x.x.x1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto dynamic-map outside_dyn_map 20 set pfs
crypto dynamic-map outside_dyn_map 20 set transform-set ESP-3DES-SHA
crypto map outside_map 65535 ipsec-isakmp dynamic outside_dyn_map
crypto map outside_map interface outside
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
telnet timeout 5
ssh timeout 5
console timeout 0
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
service-policy global_policy global
group-policy VPNTunnel internal
group-policy VPNTunnel attributes
dns-server value 192.168.1.11
vpn-tunnel-protocol IPSec
split-tunnel-policy tunnelspecified
split-tunnel-network-list value VPNTunnel_splitTunnelAcl
default-domain value .COM
username whbaxter password eCtuA/0MCMYZ4AXN encrypted privilege 0
username whbaxter attributes
vpn-group-policy VPNTunnel
tunnel-group VPNTunnel type ipsec-ra
tunnel-group VPNTunnel general-attributes
address-pool VPNPool
default-group-policy VPNTunnel
tunnel-group VPNTunnel ipsec-attributes
pre-shared-key *
prompt hostname context
Cryptochecksum:xxx
: end
Bill,
Add the below:-
crypto isakmp policy 65535
encryption 3des
hash sha
group 2
lifetime 86400
Give it a whirl and test!
Forgot this as well
crypto isakmp identity address
Andrew,
I am a little confused. this is already in my config, but the one differnece is:
should i just be modifying the one line?
Thanks, Bill
in the past I had issues getting remote VPN's working - and putting in the policy # that matched the dynamic crypto map # worked. Never got to the bottom of why - bug I suspect.
I have just put all your config in my lab pix, and added my suggestions - and a VPN client can connect no issues.
Andrew,
Thanks for you help. I was just wondering if I needed to add your suggestions addition to the config or just modify the config to match your suggesstions. I will test tonight and let you know how things work out.
Bill.
issue resolved. i was using the wrong information for the group authentication. i needed to put in the tunnel name and preshare key instead of a username and password.
