VPN client user interface and input focus
When connecting with the VPN client, the input focus is not on the field that requires input, causing the user to have to click more than necessary. It would make logging on easier and quicker if the field that requires input (usually the pass code field) has input focus.
Silver
Re: VPN client user interface and input focus
Thanks for the hint. I will certainly experiment with the simple mode. However, the input focus issue is not with the main VPN client screen, but with the popup window that facilitates the actual login to the network. The input focus of that window is on the OK button, even if the passcode field is blank. This means that one has to either click on the passcode field or press "tab" three times. It would be more logical if the empty passcode field had the input focus, since that is the first thing requiring input.
117
