vpn client ver 4.0.1 and cisco 2503
ysyong
Dear all ,
I facing problem when i use vpn client ver 4.0.1 to access to my cisco 2503 router , when i type crypto (config)#isakmp client configuration ?
only address-pool is the only option ,
so my problem is unable to key in
(config)#crypto isakmp configuraiton client group xxxxxx
sh ver as display below
sh ver
IOS (tm) 2500 Software (C2500-JK8OS-L), Version 12.2(1d), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2002 by cisco Systems, Inc.
Compiled Sun 03-Feb-02 22:01 by srani
Image text-base: 0x0307EEE0, data-base: 0x00001000
ROM: System Bootstrap, Version 11.0(10c), SOFTWARE
BOOTFLASH: 3000 Bootstrap Software (IGS-BOOT-R), Version 11.0(10c), RELEASE SOFTWARE (fc1)
Router uptime is 6 minutes
System image file is "flash:/c2500-jk8os-l.122-1d.bin"
cisco 2500 (68030) processor (revision N) with 14336K/2048K bytes of memory.
Processor board ID 09769953, with hardware revision 00000001
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
TN3270 Emulation software.
Basic Rate ISDN software, Version 1.1.
1 Ethernet/IEEE 802.3 interface(s)
2 Serial network interface(s)
1 ISDN Basic Rate interface(s)
32K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read ONLY)
Router#
wdrootz
Level 4
Level 4
Did you check whether VPN groups are supported on 2503? My guess is 2503 can only be used as an EzVPN client and not a server.
