VPN Client versions
We are running a 3005 concentrator with the latest software code. We are in the midst of pushing out an updated client to all users. I noticed that there are now 4.x versions of the client along with the 3.6.x versions (we are using the 3.6.3 client now). Are 4.x clients the preferred clients to use with the 3005 or are the 3.6.x clients the preferred clients for the 3005 concentrator? Thanks
1 REPLY
Re: VPN Client versions
Either should work fine. The 4.x client does have a lot of new features, so it's sort of up to you as to whether you want them or not. The new features are listed here:
http://www.cisco.com/univercd/cc/td/doc/product/vpn/client/rel4_0/relnotes/400_clnt.htm#1225878
The virtual adapter is good if you run things like X-Windows/NetMeeting over the VPN, it solves a lot of the problems with those apps. The single SA also uses a lot less resources on the concentrator particularly if you're doing split tunnelling.
Personally I would always run the latest version, although not necessarily the very first release of a major train. Now that 4.0(3) is out I would use that over 3.6(3).
86
