VPN Concentractor SSL Certificate Expired - Urgent Help
We have VPN concentractor 3030. Whe I log on via web its says that SSL certificate has expires and I cannot login to generate new certificate.
I even tried login via consol but it won't allow the connection.
What can I do.
Re: VPN Concentractor SSL Certificate Expired - Urgent Help
What has the certificate gotta do with the console access?
Farrukh
When logging via web GUI SSL Certificate is failing and won't allow access.
But I can't enve login via Console.
What is the error? (On the console)?
Farrukh
We don't even see the prompt. The cable and connector has been checked on other device and it works fine.
Is their any work around resolving the SSL certification issue as it has expired.
The CONSOLE has nothing to do with the certificate. No matter what you should see the console prompt. If you cannot, make sure you are using a STRAIGHT THROUGH DB9 cable.
NOTE: This cable is different from the one used by PIX 520 and IDS boxes.
Farrukh
Here is the message I get. I can't even log in to the system. None of the password work.
As a workaround try to set back the date on your system to a data before the certificate expired. Then access the GUI.
However as I said before, this has NOTHING to do with the console, it will still work.
Farrukh
315
