VPN Concentrator 3000 and Lan-to-Lan tunnel
If I've got a Lan to Lan tunnel to a VPN concentrator and part of the tunnel is the network of the PUBLIC interface of the concentrator - will I be able to access that network from the remote end? Or will it not work since that network is on the PUBLIC interface?
Thanks!
1 REPLY
Bronze
Re: VPN Concentrator 3000 and Lan-to-Lan tunnel
hi
i didnt understand what you want to achieve but i ll try to explain in brief manner a LAN-TO-LAN VPN TUNNEL may be that will clear your undestanding
in a concentrator you have a private interface and a public interface, the private interface is connected to your private lan in the most case addressed using RFC1918 no routable addressing space, and the public interface is connected to the internet it has a public ip address from a routable space other than RFC1918.
so the traffic sourced from inside your private network traffic will be tunneled through the internet using for example some algorithms to be in respect with a CIA, confidentiality,integrity and origin authenticity (in the case of ipsec)
the ip addresses of your public interfaces will be used as the outer header to route the traffic since the private ip addresses will be encrypted and in addition are not routable.
(or elaborate more what you want to achive)
do rate if it does help
177
