VPN Concentrator and Citrix - HELP
I have a 3020 concentrator. It has been a perfectly fine frond end to our Citrix system for a couple of years. We recently decided to upgrade Citrix from 4.0 to 4.5 on two presentation servers and the front end web server.
The first thing we noticed was that we were getting a cookie error. That was resolved by updating the VPN software to 4.7.2.N.
Now we are having trouble using the system through the VPN. It works great when launching the Citrix web server directly. It fails when access through the VPN concentrator. We have the right URL. The Citrix box is checked as it was prior to are upgrade. It apears that the launch.ica file is being overwritten.
Does anyone have this working with Citrix 4.5? Please help.
--Patrick
1 REPLY
Re: VPN Concentrator and Citrix - HELP
I just stumbled upon this thread.
http://support.citrix.com/forums/thread.jspa?forumID=125&threadID=84331&start=15&tstart=0
I need to test but this might be my issue. Bug CSCsk30941. Can anyone tell me if this is also a problem with the ASA? I can switch to that if it would fix the issue.
--Patrick
95
