VPN Config Help
OK, this is probably a really simple screwup. I'm new to the PIX (a 515e in this case), and it's much different than the 2611 I'm used to configuring. All I want to do is setup for a VPN Client v4. I can connect, but cannot pass traffic through the tunnel. After connection, the client can ping the PIX through the tunnel, and the PIX can ping the client through the virtual address assigned. But the client cannot access anything on the trusted network. Here's what I have:
ip local pool vpnclients x.x.17.1-x.x.17.254
access-list INSIDE permit ip x.x.55.0 255.255.255.0 any
access-list INSIDE permit icmp x.x.55.0 255.255.255.0 any
access-list OUTSIDE permit ip any x.x.55.0 255.255.255.0
access-list OUTSIDE permit ip any host x.x.193.226
access-list OUTSIDE permit icmp any x.x.55.0 255.255.255.0
access-list OUTSIDE permit icmp any host x.x.193.226
access-list VPN-NAT permit ip any x.x.17.0 255.255.255.0
ip address WAN x.x.193.226 255.255.255.248
ip address WIN-LAN x.x.55.1 255.255.255.0
nat (inside) 0 access-list VPN-NAT
nat (inside) 0 x.x.55.0 255.255.255.0 0 0
access-group OUTSIDE in interface outside
access-group INSIDE in interface inside
sysopt connection permit-ipsec
crypto ipsec transform-set ENCRYPT esp-des esp-md5-hmac
crypto dynamic-map DYNMAP 20 set transform-set ENCRYPT
crypto map WANMAP 65535 ipsec-isakmp dynamic DYNMAP
crypto map WANMAP client authentication RADIUS
crypto map WANMAP interface outside
isakmp enable outside
isakmp policy 20 authentication pre-share
isakmp policy 20 encryption des
isakmp policy 20 hash md5
isakmp policy 20 group 2
isakmp policy 20 lifetime 86400
vpngroup vpngroup address-pool vpnclients
vpngroup vpngroup dns-server [ip of nameserver]
vpngroup vpngroup wins-server [ip of wins server]
vpngroup vpngroup default-domain mydomain.com
vpngroup vpngroup idle-time 1800
vpngroup vpngroup password ********
I have a full class C on my trusted network, so no NAT. And yes, I know I'm wide open, but first things first. I'll tighten up the ACLs after I get the VPN running. And this is a secondary firewall anyway, so I'm not completely vulnerable.
Many thanks...
Paul
Re: VPN Config Help
Hmmm, actually this config looks pretty good, can't see anything obviously wrong with it. You mention that this is a secondary firewall, so does this connection go through your primary firewall, you may want to make sure it's allowing everything through. Is your VPN client behind any sort of PAT device? If so, try adding "isakmp nat-traversal" to your configuration. Also, do the internal hosts have this PIX set as their default gateway, or at least do they have a route to the x.x.17.0 subnet that points to the PIX inside interface?
Re: VPN Config Help
Right now I'm still in testing mode; the test client is connected via a hub directly to the PIX's WAN interface. So the upstream firewall is not in this equation. And the internal hosts do have their default gateway pointing to the PIX interface. What's baffling to me is that if I tracert from the client, I can see that it going through the IPsec tunnel. I just can't get past it.
Re: VPN Config Help
So is the default gateway on your test PC set to the PIX's outside interface?
Re: VPN Config Help
Yes, currently. My original test setup had another upstream router with the default gateway on the test client then set up for it, but when that test failed I removed it and put the test client directly on the PIX's WAN interface.
Re: VPN Config Help
New info on problem...
I discovered the capture command with some very interesting results. Machine A is in the protected LAN, machine B in the VPN client. I setup a capture on the WAN port to capture all traffic to/from machine B. My first test was a ping from A to B. Without the tunnel to test the capture I get:
8 packets captured
13:37:15.961070 x.x.55.37 > x.1x.193.235: icmp: echo request
13:37:15.962016 x.x.193.235 > x.x.55.37: icmp: echo reply
13:37:16.961315 x.x.55.37 > x.x.193.235: icmp: echo request
13:37:16.962245 x.x.193.235 > x.x.55.37: icmp: echo reply
13:37:17.962505 x.x.55.37 > x.x.193.235: icmp: echo request
13:37:17.963420 x.x.193.235 > x.x.55.37: icmp: echo reply
13:37:18.962734 x.x.55.37 > x.x.193.235: icmp: echo request
13:37:18.963649 x.x.193.235 > x.x.55.37: icmp: echo reply
8 packets shown
Results are as expected.
Now with the tunnel established, the same test ping from A to B:
11 packets captured
13:43:46.663539 x.x.55.37 > x.x.193.235: icmp: echo request
13:43:51.454703 x.x.193.235 > x.x.193.226: ip-proto-50, length 132
13:43:51.864594 x.x.55.37 > x.x.193.235: icmp: echo request
13:43:52.790608 x.x.193.235.500 > x.x.193.226.500: udp 84
13:43:52.790928 x.x.193.226.500 > x.x.193.235.500: udp 84
13:43:52.956829 x.x.193.235 > x.x.193.226: ip-proto-50, length 132
13:43:54.459158 x.x.193.235 > x.x.193.226: ip-proto-50, length 132
13:43:56.870575 x.x.55.37 > x.x.193.235: icmp: echo request
13:44:01.876556 x.x.55.37 > x.x.193.235: icmp: echo request
13:44:02.805546 x.x.193.235.500 > x.x.193.226.500: udp 84
13:44:02.805897 x.x.193.226.500 > x.x.193.235.500: udp 84
11 packets shown
FYI...x.x.193.226 is the PIX WAN port.
Several interesting things here.
1) PIX is placing the ping echo request on the wire unexcrypted. Why isn't the traffic using the established tunnel?
2) I see no correlated evidence of a reply from the VPN client, either encrypted of not.
3) The client is setup for UDP transparent tunneling. So why the protocol 50 traffic? I thought that was the point of transparent tunneling, to get past the ISPs like earthlink who block protocol 50 traffic.
So next I run the same capture while pinging from the VPN client (B) to the inside network host (A).
8 packets captured
13:52:28.165656 x.x.193.235 > x.x.193.226: ip-proto-50, length 92
13:52:33.393397 x.x.193.235 > x.x.193.226: ip-proto-50, length 92
13:52:35.569398 x.x.193.235.500 > x.x.193.226.500: udp 84
13:52:35.569703 x.x.193.226.500 > x.x.193.235.500: udp 84
13:52:38.400858 x.x.193.235 > x.x.193.226: ip-proto-50, length 92
13:52:43.408304 x.x.193.235 > x.x.193.226: ip-proto-50, length 92
13:52:45.584472 x.x.193.235.500 > x.x.193.226.500: udp 84
13:52:45.584762 x.x.193.226.500 > x.x.193.235.500: udp 84
8 packets shown
The "length 92" packets appear to correspond with the echo request. There is no evidence of a reply, either encrypted or not.
Anyone have a clue what;s going on here? For such a basic setup, I can't believe it's so hard to get it working.
134
