05-13-2003 10:28 PM - edited 02-21-2020 12:32 PM
I'm connectig using a vpn connection and succesfully ,check out the sample config below.
For example my VPN client would like to access to the LAN internal server 10.1.1.156
What setting shuld be done as the local IP pool addresses are different subnet and do i need
to do additional routing?Any advise
PIX Version 6.2(2)
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password 8Ry2YjIyt7RRXU24 encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
hostname ciscopix
domain-name cisco.com
fixup protocol ftp 21
fixup protocol http 80
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol ils 389
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol sip 5060
fixup protocol skinny 2000
names
access-list inside_outbound_nat0_acl permit ip any 10.1.2.0 255.255.255.224
access-list outside_cryptomap_dyn_20 permit ip any 10.1.2.0 255.255.255.224
pager lines 24
mtu outside 1500
mtu inside 1500
ip address outside 172.18.124.216 255.255.255.0
ip address inside 10.1.1.1 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
ip local pool ippool 10.1.2.1-10.1.2.30
pdm location 10.1.1.156 255.255.255.255 inside
pdm history enable
arp timeout 14400
nat (inside) 0 access-list inside_outbound_nat0_acl
nat (inside) 0 0.0.0.0 0.0.0.0 0 0
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h323 0:05:00 si
p 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
http server enable
http 10.1.1.156 255.255.255.255 inside
no snmp-server location
no snmp-server contact
no snmp-server enable traps
floodguard enable
sysopt connection permit-ipsec
sysopt connection permit-pptp
no sysopt route dnat
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto dynamic-map outside_dyn_map 20 match address outside_cryptomap_dyn_20
crypto dynamic-map outside_dyn_map 20 set transform-set ESP-DES-MD5
crypto map outside_map 65535 ipsec-isakmp dynamic outside_dyn_map
crypto map outside_map interface outside
isakmp enable outside
isakmp policy 20 authentication pre-share
isakmp policy 20 encryption des
isakmp policy 20 hash md5
isakmp policy 20 group 2
isakmp policy 20 lifetime 86400
vpngroup abc address-pool ippool
vpngroup abc idle-time 1800
vpngroup abc password ********
telnet timeout 5
ssh timeout 5
vpdn group PPTP-VPDN-GROUP accept dialin pptp
vpdn group PPTP-VPDN-GROUP ppp authentication pap
telnet timeout 5
ssh timeout 5
<--- More --->
vpdn group PPTP-VPDN-GROUP ppp authentication chap
vpdn group PPTP-VPDN-GROUP ppp authentication mschap
vpdn group PPTP-VPDN-GROUP ppp encryption mppe 40
vpdn group PPTP-VPDN-GROUP client configuration address local ippool
vpdn group PPTP-VPDN-GROUP pptp echo 60
vpdn group PPTP-VPDN-GROUP client authentication local
vpdn username cisco password *********
vpdn enable outside
terminal width 80
Cryptochecksum:e89e4bc72e8eaa1bb3c644630bfb5db3
: end
05-15-2003 08:20 PM
I was wondering how the client is going to communicate with internal server for example which have IP address of 10.1.1.156,since the IP local pool is under 10.1.2.0 segment.Do we need to put in any routing command.
05-16-2003 02:18 AM
Yes, you have to add a static route on your server.
like
route add 10.1.2.0 mask 255.255.255.0 10.1.1.1
BTW, after the vpn connection established, vpnclient get a IP address(ex:10.1.2.1).
Because the vpn connection was terminated on the outside interface.
PIX treat 10.1.2.1 as a IP address from outside. So you have to permit the traffic from 10.1.2.1 to 10.1.1.156 on the outside interface,
or use "sysopt connection permit-ipsec" command to let all ipsec traffic bypass the security control.
05-17-2003 12:31 AM
thks for the response.If I chose to put the comand in the router instead of the server will it work?
BTW if I assigned my local IP pool in my PIX to be the same segment with the LAN will it save the routing job.
