VPN COnnection to Watchguard
ohliger
Has anyone implemented a VPN (IPSEC) connection between a cisco router and other devices ? We want to implement a cisco-watchguard communication.
Christoph
s-doyle
Level 3
Level 3
I would avoid it if you can. I know that Cisco was testing with Watchguard a while back when I was trying to get it to work; we ended up using a small PIX on the other site. Technically, it should be possible if you are tied to this setup but it’s difficult getting vendor-to-vendor support.
jkrinn
We have done and it worked just fine. We are only sending minimal traffic across it. If you have a good understanding of how the key exchange works for both firewalls you shouldn't have any problems.
